Spec Boxsters For info sharing on this exciting new class
Aftermarket Shifters
Old 03-05-2017, 09:34 PM
Surfbum
Surfbum's Avatar
Default Aftermarket Shifters
Joining the Spec Box Club, I've looked at Numeric and CAE, are both legal?
I put the CAE in my E46 and it works really well with that box, I was wondering what others thought of the two.
Old 03-05-2017, 09:35 PM
Surfbum
Surfbum's Avatar
Ive been told the short shifters might be the cause for gearbox failures, any comments?
Old 03-05-2017, 10:04 PM
bkovac
bkovac's Avatar
I run a CAE w POC and PCA races. The shift is slower but precise. No $$$ shifts. I have it in my spec boxster. You going to run with us? The field is growing nationally as well as the talent level racing in it. You will need to modify the ends of your stock cables.
Old 03-05-2017, 10:19 PM
Surfbum
Surfbum's Avatar
bkovac, the plan is to run the POC and some PCA events. Anders has been telling me what a blast its been and I was really surprised at the numbers at Willow.
Old 03-05-2017, 11:26 PM
bkovac
bkovac's Avatar
God I hate Anders, make sure you tell him
Old 03-05-2017, 11:28 PM
bkovac
bkovac's Avatar
hes lonely, he needs more competition. We are implementing a 3 tire rule for him only. We had 15 BSR at willow and have 12 signed up for next week at Buttonwillow. Have you found a car?
Old 03-05-2017, 11:49 PM
bkovac
bkovac's Avatar
i meant 3 wheel rule for him
Old 03-06-2017, 01:21 AM
altonj
altonj's Avatar
CAE and Numeric are both good. But like with any short shifter one needs to decide why they need one. If it is just to reduce movement, great. If it is to reduce shifting time on the upshift then one must be prepared for increased syncro wear.
Cheers
Old 03-06-2017, 10:04 AM
mmuller
mmuller's Avatar
I like the OEM 997.2 GT3RS shifter myself. Its shorter than stock, but requires no extra leverage. It has metal bearing in it and isnt a terrible price. I put it on top of the Rennline 7" shift riser so its nice and high and closer to the steering wheel.
Old 03-06-2017, 11:34 AM
katmeho
katmeho's Avatar
I have stock and after this weekend am hoping to have a solution that doesnt result in a higher chance of damage to the trans. I was told by numerous people at COTA that anything other than stock WILL cause failures and that I need to be prepared to fix those if I make the change. Is there really nothing durable in the market thats OK to use?
Old 03-12-2017, 12:52 AM
altonj
altonj's Avatar
what problems are you looking to solve? You seem unhappy with the stock set up, so what are looking to improve?
Old 03-12-2017, 01:41 AM
audipwr1
audipwr1's Avatar
I have a modified rennline shifter riser which can solve the problem a bit
Old 03-12-2017, 08:05 PM
katmeho
katmeho's Avatar
Mainly the mushy feel that I have with the stock setup.
Old 03-16-2017, 11:31 PM
altonj
altonj's Avatar
Any of the more solid bushed shifters mentioned will help, as will cables such as those made by Numeric (if legal). Just be careful of how much the shift throw is reduced.
cheers
Old 03-17-2017, 12:07 AM
mmuller
mmuller's Avatar
cheers
THIS
Quick Reply: Aftermarket Shifters
