Brake Pads
In the Pagid line, some like the RS29 for longevity and because they are easy on the rotors. For more stopping power, the RS14 works really well on an SPB. I raced one on both and preferred the RS14 and found that they weren't that much harder on the rotors. Liked the PF08s as well but I really liked the RS14 we used when I co drove the car in the EMRA 4 hour race at Summit Point a few years ago. No fading, no boiled brake fluid.
Kind regards,
Kind regards,
Thanks for the reply Mark!
Jay, No SPB for me, but I am working on fitting a set of boxster brakes on the 914 and was just wondering what the best pads are as the cars. The rotors I am using are also boxster rotors so I was thinking I would find out what luck you guys had and mimic it. Hope you had a good Christmas!
Depends on your braking style really...
Gentle as a kitten: Pagid Orange Fronts / Pagid Black Rears
A little bit more teething and back scratching: Pagid Yellow Fronts / Pagid Black Rears
Shave the cat and twirl it around your head: Pagid Black fronts and rears
Any of the above but care less about feel and don't like to change pads often: PCF 08 fronts and 11 rears
Good to learn. Thx!
I found black fronts took the Rotor with it each pad change so I stopped using them
Oranges have less stopping power than yellows so don't understand how it would add more rear bias. However, if you believe that the operating temperatures in the rear does not get the yellows high enough to be effective.... which is a reasonable position.
Use blacks front and rear. I use one set of front rotors a year (6 race's, 10 open lapping days) and one set of rears every 18 months.
Agree with Feueracing, feel is what your looking for. I use 2 sets of fronts pads and one set of rear pads a year. If your using lots of pads, your doing it wrong.
My feel tells me my front brakes are doing the lion share of work - used two sets of rear pads on 22 days on the car this season
I'll kill a set of black fronts in 2-3 race weekends depending on track
The tracks you run require big braking zones? We have a few 110+ down to 30 turns out here
Every track out here has at least two turns where I'm maxed out on BPS for a bit
No custom brake ducting at all. Stock brake ducts.
Not sure what to tell ya - my results say I'm doing it right, are you using custom brake ducting or something? I just have cup control arm air guides
Some of the tracks we run do have big brake zones, especially high speed sweeping brake zones. My SPB will often see 132 at some of the tracks we run, right before 60-70 mph corners.
That sounds great, but how?
Assuming speed to turn in point is fixed and that you can trail brake you need to go from speed down straight to speed at Apex
Option 1 brake less hard and longer = slower
Option 2 brake harder less distance = can brake Later = faster
Harder braking = more wear
BPS overlap mine versus the pro I hired to help setup my car who has imsa cayman and PWC cup seats was identical (as was everything but my slow crap upshifting) so I'm missing how I can use less brakes by technique?
I can use less by cooling front more or getting more rear bias through pad / Rotor combos for sure - less brake use would be slower lap time
