Part # for metal clutch slave
11-28-2016, 02:55 PM
I'm having challenges getting my clutch pedal firm and responsive
Plan is to replace all parts in the system - I have heard there is a later gen clutch slave that is metal and stronger
Can someone point me to the part #?
11-28-2016, 08:02 PM
The universal part number for me is John Gladwill's cell number.
11-28-2016, 10:40 PM
That's funny!! That's how I get all my info too!
11-29-2016, 02:22 PM
Have said part number now thanks Chris
Hopefully fewer than 4 transmissions next season...
11-29-2016, 07:15 PM
I'm in....Rennlist Member
Quote:
Originally Posted by
audipwr1
Dude. What are you doing to those things? I'm on the same one for the past five years. I have gone through three engines though.
11-29-2016, 07:18 PM
Quote:
Needed new slave cylinder my old one wasnt right
11-29-2016, 07:35 PM
I've heard of bad engine mounts being an issue with transmission smoothness as well..
11-29-2016, 11:18 PM
audipwr1
I just did my second transmission in 4 years of racing. And the last one came out of a crashed SPB.
Now I don't feel so bad. Hope that replacing all the parts fixes the problems.
11-30-2016, 12:20 AM
Yeah my clutch doesn't really work so makes for a bit harder on the gearboxes - I like the every other season cadence
12-06-2016, 11:57 PM
audipwr1
Something is wrong with car Either clutch hydraulics or mechanical system / we are replacing every single part to be done with this I had to double clutch all my end of season races and for one had to manually pull clutch pedal back up after each shift - not ideal
I'm not a wrench by any means but I've heard folks talk about bushings in the old 911s transmissions.
Could that have any relevance whatsoever here?
12-07-2016, 01:50 AM
Hmm - it could be a few things - I have Brad (and John) on the case so am sure they will make it happen
12-07-2016, 08:30 AM
bad clutch
Had a fellow SPB that complained all the time about his clutch pedal.
Found out he had the disk in backwards
Mark
12-08-2016, 02:49 AM
Which way does clutch go in?
12-08-2016, 05:39 PM
Flat side toward the flywheel.
