New tire proposal
Perfect Angel
New tire proposal
Does anyone have any knowledge of the Toyo RR? Specifically longevity.
I jumped out of the "stock" classes and into the SPB because I didn't want to buy new Hoosiers every weekend. So far the RA1's have been fantastic and cut my tire bill by at least 70%. I'm not sure what "complexities" are being referred to in the rules proposal but I find them to be easy and cheap compared to Hoos.
So, will the RR last as long or are we deciding to leave the cost conscious philosophy of our spec class behind?
The Toyo RR is a RA1 that is molded to 4/32 instead of 8/32, as a result the casing is also slightly reinforced.
A Toyo RR should be slightly faster than a RA1 shaved to 4/32 due to the reinforced casing. The rubber compound and longevity should be the same. The Toyo RR was introduced last year at NASA Nationals. There are number of NASA classes that started 2013 on the new RR with very favorable results. As always some embrace change and others reject it.
I heard a few production runs delaminated. Presumably they have this sorted out by now.
I guess we would run RRs in the dry and full tread RA1s in ze rain?
That is the idea. Toyo expects the RR's to be available in the Spec 986 sizes by the end of the year. The goal is to provide competitors with the opportunity to purchase and begin testing with those tires by the start of the new year
Can you get TOYO to get you some data?
A guy I know who races Spec Miata came to our (multi-marque) club considering a proposal to allow the RR as a direct equivalent to the RA-1 even though under this club's rules it would normally have a classing points penalty applied because the RR is treadwear 40 (that's the cutoff for us) and the RA-1 is treadwear 100. Here's what he had learned so far about the RR:
"The consensus in the spec miata community is that they are equivalent to a really good set of heat cycled RA1. The top guys have been able to get a maximum of 0.7 secs out of a set of stickers, and dropping off immediately. Us mortals cannot get any better performance than our best RA1."
The Tire Rack page says the RR will become the NASA spec tire starting 1/1/2013 for Spec Miata, E30, and 944; and for other classes as their sizes become available. Tire Rack pricing for RR is $186 per tire than vs. $180 for RA-1, for 225/50-15.
Former Vendor
Sorry, I sell the tire infrequently enough that I don't have much feedback on longevity that users have reported back to me. Since they basically come "pre-shaved" they should hold up pretty well. I'm watching this for feedback as well!
The Penguin King
I'm running the RR on my SM, and love the tire. It's difficult to get a good handle on lap times compared to the RA1 without running them under identical conditions, but my sense is that they are about .5sec faster than the RA1. I'm not seeing much fall off on the tires with heat cycling, and I've been running them to the cord. I would describe the tire as confidence inspiring. Good grip, and a good progressive release. I've not heard anyone in she Spec Miata field complaining about them.
The delimitation issue happened with some of the early tires. I've seen it, but not experienced it myself, and I think the problem has been solved.
If they would make them in SP996 sizes, I would love to try them out in that class as well.
Perfect Angel
If the treadwear is a 40 vs a 100 for the RA1 it seems like it is quite a bit softer and will wear out faster no?
I'm in....
hmmm. I just sold my last set of new (but redundant) R888s on eBay for $40 each. Hope I don't end up with three sets of useless RA1s when it is deemed we should change!
So, by the sounds of descriptions so far - they feel, look, lap and cost about the same as an RA1 but they won't work in the rain!!!!!! And the reason to change is???? This is a spec class and we all run with the same advantages/disadvantages as each other. Why would we change anything if it doesn't improve safety, longevity or running costs?
They work in the rain about as well as your RA1 shaved to 4/32. The rain tire would remain a RA1 at full thread of 8/32.
The reason to change is to be able to use a version of the same tire we already have that has been made in the thread depth that most of us would use and to eliminate the need to shave every brand new set of RA1 we purchase. Shaving does tend to have varying levels of consistency. My guy is pretty good but every once in a while I get one cut a little more on the outside or inside, etc.
I am curious if you do not see a benefit as a driver?
-P
-P
