Wheels: How narrow for 4S in snow?
Hey folks,
You all were really helpful in my other thread. Thanks!
Some recommended narrower wheels for the winter. How narrow are we talking?
Is 8 in front, 9 in the back too narrow? Found some 18" Cayman S wheels nearby for a good price.
Thanks!
Thanks!
The fronts are fine. The problem is the backs. No one makes an 11 inch wide snow tire. So what I did was pick up a set of wheels for a 911 Carerra. The front wheels are the same and go right on. The backs are I think 9 inch and will also go right up but look kind of odd if you just put them straight on. You can solve that by getting a set of one inch spacers that push the back wheels out an inch and make them look better. It still doesn't look as good as your 11 inch wheels but it is hardly noticeable.
You can buy winter tires for the 9 inch back rims and the front rims whatever those are.
Typical winter set up is:
Front: 8" rim: 225-235/40-18
Rear: 10" rim: 255-265/35-18
Nokians are best there are. Narrower is better. Adjust offset if needed.
997.1 C2S
997.1 C2S
That is an excellent way to go. Another way is 19s but then the rears are 295. Of course it floats a bit more than with 265s but I find clearance more of an issue than traction.
Too narrow or "safe" depends on the tire not the rim. What tires are you going to put on? If your going to put 265's on a 9" rim check tirerack or somewhere to make sure that combo works
Rocky Mountain High
If you decide to go with a narrower rear tire than Porsche recommends, then you should check the load rating. There's lots of weight back there....
I'm running 295 in back ;-)
Rocky Mountain High
Rocky Mountain High
The only concern that I would have with going with a very narrow tire is load rating, as mentioned above. I think you also need to consider how you plan to use the car in winter conditions. I spend more time in the winter months driving my Porsche on cold, dry pavement than I do driving in snowy or icy conditions. The 295s are a good choice for me.
I have another vehicle for sloppy, slushy roads.
The C4S already sits fairly low to the ground versus non 4S. Reducing the wheel size from 19's to 18s drops it even further...so not good clearance for unplowed snow.
19" diameter with 295 wide tires works well in Northern VA (i.e. the size recommended by Porsche) which typically gets a few inches of snow now and then, plus a few larger snowfalls that causes WDC to come to a grinding halt, but is usually fully plowed in a couple days. In this region, its more about driving in colder weather.
More often, I jump in the X3 when things gets bad!
I just bought a set of Pirelli Sottozero SerieII in 235/40R18 91V N1 for the front and 265/40R18 97V N1 for the rear of my 2009 C4S. I live in northern Wisconsin and intend to drive it through the winter here. I've been driving a Passat TDI without snow tires for the last three winters and always managed to get to work on time. I'll let you know come spring if I made a good choice or not, but the C4S is only an inch or so lower than the recalled Passat and it's all wheel drive. Tire Rack has them on sale and are offering a $50 store credit and a $50 prepaid visa or some such, so I just got the wheel and tire package that "fit". In the past, I've used Blizzaks when I needed winter diggers, but none fit. I looked at the Nokians as well, same issue and I didn't want to go the "narrow tire with spacers to fill the wheel wells" route. The studded Nokians are what the ice racers up here swear by for a road use car that goes out onto the frozen lakes. I'm no where near crazy enough to try that.
You will get to work on time. Your only concern is other people without snow tires (like you last year ) running in to you
My 4S is also on H&R springs so even lower clearance but it was fine last year although we didn't have much snow
