View Poll Results: Pin now or weld later?
Drive it as is, do the weld and lsd rebuild in the dead of winter
12
50.00%
Do the DIY pin now to avert disaster; coolant elbow and lsd rebuild in the winter
7
29.17%
Do nothing, roll the dice.
5
20.83%
Voters: 24. You may not vote on this poll
Not this crap again. Pin now or weld later? Vote my destiny
I should have a 997.2 GT3 coming in, great drivers car, clean PPI, 36k mileage.
It's now towards the end of the summer, my plan was to drive it as is until the winter when I put it away and have plenty of down time to do the following: coolant line fitting fix and LSD rebuild.
Saw Steve's engine-in DIY pinning. And, also the alarming 15-20% failure rate (coolant loss) in stock (no fix) motors.
Car will be a daily driver, but like my previous F80, be tracked 1-2days a year. 1st track event won't be till next season (2017).
The shop I will probably go with is TPC Racing, who weld, but they pressure test @15psi to assure weld integrity.
So do I...
So do I...
15 -20% failure rate for pinning? Where did that come from? I've got a 100% success rate on my n of 1. Only way to know the failure rate of pinning is to track a large number that have been pinned and track failures. Shrakwerks developed pinning and likely do a large number. Did they report this failure rate? Or more likely is this Internet Statistics where someone pulled a number out of their a$$.
To answer your question, do what makes you comfortable. Just don't track the car until it's done.
GT3 player par excellence
to not pin/weld is like jumping out a plane without parachute. you will LAND at some point.....
pin/weld if done right both are fine. there's no need to argue what is better.
pin weld if done wrong, both fail
i have variations of all of the above.
If you track your car you have obligations to those you share the track with. Fix it ASAP. If this is just a daily driver, then the worst that is likely to happen is that you will get stranded, and your timeframe is far more open.
Ray
Ray
