How are you ratcheting low nose cars in trailer
Old 07-25-2016, 09:21 AM
grrrmonster
grrrmonster's Avatar
Default How are you ratcheting low nose cars in trailer
My GT3 has rennline hooks on jacking points behind front wheels. When I hook in there, the front hooks in trailer floor are so close that there is not room to operate the ratchet unless I pull the car in on top of 2x10's. I really don't like doing that however it's the only solution I have
Old 07-25-2016, 09:50 AM
ExMB
ExMB's Avatar
Received 1,310 Likes on 796 Posts
I replaced the short straps on my ratchets with
to give me more room. Looks like
now instead of
Old 07-25-2016, 01:37 PM
Jon951
Jon951's Avatar
I did the same thing. Works better. Does anyone leave the winch hooked up to the front tow hitch when traveling?
Old 07-25-2016, 04:32 PM
Viperbob1
Viperbob1's Avatar
Install new recessed tie downs maybe further off to sides? and or with ratchet strap above
Old 07-25-2016, 04:40 PM
jdistefa
jdistefa's Avatar
A-track or E-track? Then you can optimize your strap placement.
Old 07-25-2016, 11:27 PM
stujelly
stujelly's Avatar
[IMG]https://cimg1.ibsrv.net/gimg/rennlist.com-vbulletin/175x175/80-2671_2_ratchet_with_snap_hook_1_175_96710f90edb546bbdc0b84021ed61bdce745 ade8.jpg[ ^
now instead of
this^
Old 07-26-2016, 08:21 AM
grrrmonster
Thanks. Hadn't seen the shorter ratchets. Ordered a pair
Old 07-26-2016, 11:09 AM
Trailers of the East Coast
Former Vendor
Trailers of the East Coast's Avatar
This is the most popular solution these days -- we'll run multiple runs of recessed E-track set to the track width the customer requests, allowing for ease of adjustment to each car.
The Mac's Tire Block straps are popular with folks that choose airline track (or VersaTie track as Mac's calls it).
- Matt
Old 07-26-2016, 12:29 PM
Gary R.
Gary R.'s Avatar
Yes, just as a final safety measure I hook it in but don't winch it tight. Has about 2" of play (just enough to make hook/unhook easy without running the winch).
Old 07-26-2016, 01:57 PM
ExMB
ExMB's Avatar
You should be able to just get the snap hooks and then do an R&R on your existing ratchets. At least thats what I did to mine.
Old 08-26-2016, 02:07 AM
cre8fun
cre8fun's Avatar
don't know if this will work for you. I hook in behind front wheels and can't reach my front ratchets once car in hooked in. so I set my front strap lengths so they both tighten equally when the car is in the desired position, so they are preset
when I winch the car in, I pull past the desired position. hook up the front straps. then let the car roll back till the fronts are tight. then hook the rears and ratchet the rears till all 4 straps are tight. done.
I've not touched the front strap ratchets in a long time. when car is tied down, they are beneath the front spoiler.
hope that makes sense
Old 08-26-2016, 11:05 AM
kgorman
kgorman's Avatar
We used chain on the front with shackles, then ratchet straps in the back. So bring the car in, hook up chains, let the car move back to tighten against them, then ratchet the back.
Old 08-27-2016, 08:02 AM
grrrmonster
Great suggestions
Old 08-28-2016, 01:05 AM
Moondog4224
Moondog4224's Avatar
[QUOTE=ExMB;13475928]I replaced the short straps on my ratchets with
Who makes these?
Old 08-28-2016, 01:57 AM
ExMB
ExMB's Avatar
Who makes these?
Google
Quick Reply: How are you ratcheting low nose cars in trailer
