964 Forum 1989-1994
964 RSR Inspired Replica
Old 10-02-2014, 02:35 PM
mark my words
mark my words's Avatar
Default 964 RSR Inspired Replica
This is my way to say hello to this forum.
After just reading all these amazing threads of building and rebuilding some nice Carreras I want to share my own version of a lightweight Carrera 4.
These are some things i have done:
Complete gutting of the interior
Weight reduction of about 210 kilos
Complete paintjob including interior
Recaro Pole Position seats and consoles
Schroth belts
RS door panels
RS ducts
Cup front splitter
Cup mirror
Momo V35 Sport steering wheel
Radio and wiring removed
Switch panel instead of radio
Air conditioning and wiring assembly removed
Makrolon rear and rear side windows
Porsche 996 GT3 wheels
RS motor vehicle without air conditioning holder
Techart Cuprohr
Single-mass flywheel
Sachs Sport clutch
Rigid motor mounts
Removal of the large windscreen washer fluid tank
Headlight cleaning system was Removed
All add-on parts ( and motor parts ) were new yellow chromated
Engine Revision:
New are :
• Cylinder
• inlet valves
• exhaust valves
• valve springs
• Brombacher camshaft
• timing chains
• Slide rails
• Connecting rod bolts
• All bearings and seals
Have been revised :
• Cylinder heads (planning , valve guides , conversion to cylinder with seal )
• Oil pump
• Connecting rods
• Crankshaft
Next thing to come is a Bilstein B16 PSS10
Let me know what you think...
PhillyNate (07-13-2019)
Old 10-02-2014, 02:37 PM
911Jetta
911Jetta's Avatar
I think you win the introduction post award this year!!
OMG! Wow, just wow.
The work you've done on the interior is just amazing! I love seeing the car's color inside, it looks so honest and simple. Nice routing of the black heater duct hoses.
You've done a fantastic job of hiding everything behind the shorter dashboard knee panel. Very clean.
Is the interior dramatically louder naked like this?
Tell us more about the switches, is one a spoiler switch?, the key image is to turn on the power?, what's "F"??.
Gorgeous finish on the engine fan too.
Weight reduction of about 210 kilos...Single-mass flywheel...rigid motor mounts!
It must feel so alive!
Old 10-02-2014, 02:38 PM
BLACK-BETTY
BLACK-BETTY's Avatar
Awesome, awesome, awesome and loving your gear **** - where's it from?
Old 10-02-2014, 02:43 PM
LPMM
LPMM's Avatar
Incredible work, I love everything about it. Can you provide more info on the shifter?
Old 10-02-2014, 02:50 PM
Jjm4life
Jjm4life's Avatar
What a build! Loving the stripped interior. It's just so damn clean. In for more info about the switch panel. What kind of hp does it make?
Old 10-02-2014, 02:59 PM
mark my words
Yes, it is LOUD - really loud...
The panel for the switches is made from a thick aluminum. I machined it to perfect size, drilled the holes, put the switches in and that's it.
The upper part of the shifting **** is a lightweight universal Aluminum **** of E-Bay - the lower part is a carbon fiber part (with a black paint job) that I managed to fit to the upper part
Old 10-02-2014, 03:06 PM
sc
sc's Avatar
Terrific job! Just simply amazing! One of the best I've seen.
Old 10-02-2014, 03:15 PM
breljohn
breljohn's Avatar
Best first post ever!
Old 10-02-2014, 03:21 PM
LimmetED
LimmetED's Avatar
Oooooooh what a tool!
Old 10-02-2014, 03:32 PM
RicardoD
RicardoD's Avatar
Wow, this car looks great. Nice job. My silver C4 is jealous!
Old 10-02-2014, 03:34 PM
Streetdaddy
Streetdaddy's Avatar
Incredible 964 ****. Mine is a daily driver, but i really would love to turn it into a beast like yours. How did you attach the **** to our factory shifter? I am looking into this as we speak. Is the carbon fiber shaft just a cosmetic sleeve?
Old 10-02-2014, 03:46 PM
mark my words
First of all: thx for all the nice words!
Cosmetic sleeve is the best way to describe the carbon fibre shaft.
I machined a aluminum shims that connects the universal shift **** to the factory shifter, thats why the carbon fibre shaft is no bearing component.
Old 10-02-2014, 04:02 PM
freedman
freedman's Avatar
Beautiful, some really nice touches, the switch panel is lovely
What did you do with your brake and clutch pedals? they look very good
Old 10-02-2014, 04:28 PM
Earlydays
Earlydays's Avatar
Outstanding!
LimmetED
LimmetED's Avatar
Looks like griptape, remowed rubber?
Quick Reply: 964 RSR Inspired Replica
