Advice on Boxster purchase decision ...
I thought I would put it out here to and get a general opinion...
I am looking to intro my wife into the world of P . Since I sold my '16 981 for a '17 991.2, she now misses a convertible. She would like to get a "toy" of her own. ( That sounded wrong just as I typed it ). So here is where I am at .
2 Vehicules, both at 2006 Boxster Base . both with 40 000 KMS . and both same price exactly. Here is the dilemma.....
One is Canadian, very clean, Atlas Grey on Tan, AUTOMATIC No carproof.
The other is Manual, Black on Black, previous US, front end more chipped, not as clean as the other, AND 3000$ carproof.
Should I opt for one of these....which would you choose ??
My other option would be for a 2010, but at 15K$ more.... different topic
Thanks in advance for your input !
The 987 is an excellent car. The 2006 still has the IMS concerns so you should possibly consider an LN upgrade if it has not already been addressed ( about $1500). Otherwise, if your wife is okay with the Tip, I'd go that way. These transmissions are often referred to as bulletproof, and you can be sure that there are no over-revs ( R2), as the tip won't allow the engine to pass redline. In any case, insist on an independant PPS (pre-purchase inspection) either at the dealer or a recommended indy. It will be the best $200 that you will spend!
I'm driving a 2001 Boxster S with a tiptronic and I really like it, even at the track!
Thanks for your input Newart. Researching the IMS issue, it seems like MY06 and higher should be ok due to the larger shaft bolt ?! Would love to have have confirmation of such.
Also, any P I would get would definately get a PPS for sure.
Anyway, I misspoke on the LN upgrade price, which applies to the 986. The 987 situation appears to be better and if you keep the oil clean and drive the car like it should be driven, you should be good. Any mechanical device can fail but most don't if properly maintained. Drive it and have fun!
For extra insurance on the tiptronic have the fluid/filter changed. If you do track it an extra trans cooler wouldn't hurt...
3000$ Carproof? Yea that can be a bumper cover and one of the insta break because I hit a small curb radiator..
Purchase done, and neither of the two was the one
Went with a 2010 987.2, 36 000 Kms , Manual Transmission. The Mrs. will be happy. Next step....getting her into DE days .
Thanks for responses
