Plastic headlight refinish in MTL
Old 02-19-2016, 05:30 PM
Dwane
Dwane's Avatar
Stan, the sanding is key. You definitely ended up with a better result even if you only used the 1500. A lot of folks use just the compound and polish and that just doesn't allow a result that lasts.
You have a PM
Old 02-19-2016, 09:03 PM
Boxster dude
Boxster dude's Avatar
Dwane
I hear you, I assume the compound/polishing should be the final surface finishing not the first and only step. We know, headlamps are subject to a sandblasting effect over time so you are right, the wet sanding is the critical step...but not for the faint at heart, a screw up here could be costly.... for our Porsches, when in doubt seek out a Pro.
Thanks for the PM.
Quick Reply: Plastic headlight refinish in MTL
