WTB: AMB TranX 260 transponder
Hi Phil
Yes I did see that one, just wanted to know if anyone was selling locally before pulling the trigger on that one.
How's the green machine?
It's still in the trailer,i'm finishing the install of a two post lift in my garage then i'm going to pull the engine for a rebuild, all stock of course
Cheers
Phil
Cheers
Phil
AMB X260 direct wired. 1 year of use, for a reasonable price. Now just have to connect it to the Di-lithium crystals and we should be good to go.
Any suggestions on best place to connect - fuse box or direct to battery?
Ideally you want to have it switched inside the car,otherwise the easiest way is direct to the battery and you run a ground to the fender wall, that way it's always on ... I like the option of being able to turn mine off in case i don't want to be timed !
Mount it as close to the ground as possible and out of the way of any water slpashing/infiltration !
Cheers
Phil
Cheers
Phil
Cheers
Phil
Cheers
Phil
