Another Team RennSpoon project " LATEST UPDATE"
Old 08-03-2013, 08:26 PM
  #31
DRPM
DRPM's Avatar
Originally Posted by Dwane
**** only......Sorry
I was trying to be discrete
Old 08-05-2013, 02:05 PM
  #32
Sysgen
Sysgen's Avatar
Originally Posted by ibeaudoin
Do you need a wrench for this?
What about you Steph, you forgot to post pictures? Talk to us my friend.
Et voici quelques une, I've been quite busy, Merci a Michel pour son aide et expertise a refaire mon moteur
From this
To This
Finaly to this !
Old 08-05-2013, 02:24 PM
  #33
Dwane
Dwane's Avatar
Sweet....how much mileage on the motor before rebuild?
Old 08-05-2013, 02:54 PM
  #34
Sysgen
Sysgen's Avatar
Between 180,000-200,000 miles, it's an estimate cause the odometer has been broken for a long time.
Old 08-05-2013, 03:12 PM
  #35
ibeaudoin
ibeaudoin's Avatar
Nice,
You need to break it in at the next DE
Old 08-05-2013, 03:23 PM
  #36
Sysgen
Sysgen's Avatar
I hope you meant to say "Break it in" I don't want to break it !
Old 08-05-2013, 05:59 PM
  #37
Dwane
Dwane's Avatar
Miles! Wow!
Nice,
You need to break it at the next DE
You need to excuse him....he's French(Parisienne)
Old 08-05-2013, 06:12 PM
  #38
ibeaudoin
ibeaudoin's Avatar
Ok, je vais parler en "parisienne" comme dirait Dwane... Y peut même le dire comme il le faut en anglais....pffff
Qui a dit "break it" ?
Tu viens roder ton moteur au DE de Septembre (ou même celui du mois d'août) ?
Old 08-05-2013, 06:15 PM
  #39
Dwane
Dwane's Avatar
Make it September Stef....not sure I will be healthy enough by the end of this month!
Old 08-05-2013, 06:18 PM
  #40
Sysgen
Sysgen's Avatar
Still ironing out the bugs, I still don't know if I'll make an event this year. That engine rebuild busted my budget.
Old 08-05-2013, 10:41 PM
  #41
wildcat077
wildcat077's Avatar
Steph,
Engines really do bust a budget ... lol ... yours sure looks good though !
I'm going out for a road test tomorrow morning and if all is well,will probably
make a trip to ICAR and see how the new engine feels !
Cheers
Phil
Old 08-07-2013, 04:15 PM
  #42
wildcat077
wildcat077's Avatar
3.6 install final report !!!
Took the car out to ICAR in Mirabel last night for a spirited session to sort out the eng temps and possible leak issues and all went well,perfect temps and no oil leaks.Sure revs a lot quicker than my old 3.2 and the torque is there at lower RPM's,should be interesting at LCMT !
The fiberglass bits are fitted,although my painter is on vacation so i spray painted them flat black until he gets back and matches them with the rest of the car.
What a crappy track though ... bumpy as hell,no reference marks and the sunset clearly in your eyes making it almost impossible to judge where the track is at certain points ...
The track being concrete also made it very slippery as well in some corners where you have paved asphalt and concrete transitions.
Hope to see y'all at LCMT at the end of the month
Cheers
Phil
Old 08-07-2013, 04:38 PM
  #43
ibeaudoin
ibeaudoin's Avatar
That's good news. Congrat.
Now you need to correct that stance, rear is slightly too high.
A Phil corner balance special will be required.
See you at the end of the month.
Old 08-07-2013, 05:21 PM
  #44
Dwane
Dwane's Avatar
It's ALIVE!
Good job Felipe!
Old 08-07-2013, 06:08 PM
  #45
wildcat077
wildcat077's Avatar
Ian,
All four corners probably went up at least one inch due to the fiberglass bumpers and interior insulation removal !
I'm going to put it on the scales this week and do a "Felipe special" corner balance ... just hope i don't have to reindex the &*^#%# rear torsion bars ...
Cheers
Phil
Quick Reply: Another Team RennSpoon project " LATEST UPDATE"
