Another Team RennSpoon project " LATEST UPDATE"
Old 07-31-2013, 10:04 AM
wildcat077
wildcat077's Avatar
Off to WeTune to give Andrew back his ECU ... i'm just hoping my car will start with mine which is a driveblock unit,otherwise i have to ship it out to ECU Doctors in Florida to have the driveblock disabled.Already spoke with Jorge and he promised a quick TAT should the need arise ...
Still have a small oil leak from the oil pressure switch sender,although the access is good if i remove the right hand side intake stack.At least things look promising from this point on and i certainly hope to be at LCMT at the end of August,possibly with a multicolored car if i don't get my fiberglass bits painted in time !
Cheers
Phil
Old 07-31-2013, 11:19 AM
Dwane
Dwane's Avatar
Hope you make it to the August event.
It would suck to only do 1 event in the season.
Later
Old 07-31-2013, 12:51 PM
wildcat077
wildcat077's Avatar
YIPPPEEEE ... my Steve Wong chipped ECU works,although the base idle is fixed a little higher to offset the lightweight flywheel stalling issue !!!
Steve explained to me last week that the driveblock software should not have any effect on my car but i guess that was too much technical mumbo jumbo for me to understand at the time ... lol
Now i can move on to the rest of the car and the ill fitting bumpers headache where the mounting studs for the front and rear will have to be repositioned and reglassed ...
Oh well ... could be worse !
I'll post some pics after i have the fiberglass bumpers and rear decklid fitted !
Cheers folks !
Phil
Old 07-31-2013, 02:06 PM
Charles A. Toupin
Charles A. Toupin's Avatar
That is cool!!!
Looking forward to see and hear that!!!
c.
Old 07-31-2013, 09:57 PM
DRPM
DRPM's Avatar
video with sound would be good too
Old 08-01-2013, 08:47 AM
wildcat077
wildcat077's Avatar
Derek,
I'm not sure how to post a sound video ...
Perhaps someone could guide me through !
Took care of the leak from the oil pressure switch and started glassing in the protective grill for the oil cooler as well as bonding the brake cooling duct extensions to the front bumper last night ... did i ever mention i hate doing fiberglass repairs ???
Cheers
Phil
Old 08-02-2013, 08:57 PM
Matt Lane
Matt Lane's Avatar
Bumpers are like brassieres. Just go natural.
Old 08-02-2013, 11:19 PM
Dwane
Dwane's Avatar
Brassieres.....you sound like my grandma
Old 08-03-2013, 07:55 AM
DRPM
DRPM's Avatar
Originally Posted by wildcat077
Derek,
Cheers
Phil
I am not a video expert, maybe Dwane ?
Old 08-03-2013, 08:07 AM
wildcat077
wildcat077's Avatar
The rear fiberglass decklid is at the painter's and i'm going to spend this lovely weekend in the garage to get the bumpers ready for paint by Monday morning ...
Tomorrow the car is going out naked (brassiere-less) for a ride around the block,regardless !
Need to get some heat in the engine in order to get the rear thermostat to open up and fill the oil lines to the front mounted cooler,i'm sure i can add at least another two liters of oil !
Any tips on adding a sound video ?
Cheers
Phil
Old 08-03-2013, 09:28 AM
Sysgen
Sysgen's Avatar
Just upload your video to youtube then once it's uploaded just paste the link here.
Old 08-03-2013, 10:10 AM
ibeaudoin
ibeaudoin's Avatar
Do you need a wrench for this?
What about you Steph, you forgot to post pictures? Talk to us my friend.
Phil, so what was the problem? Sensor and/or electrical?
Old 08-03-2013, 11:20 AM
wildcat077
wildcat077's Avatar
Problem was one of the DME conversion harness wires was not connected to a proper terminal on the fuse panel ... it needed 12 volts switched AS WELL as 12v while cranking.Where it was connected prior,there was 12v with the ignition on but there wasn't enough voltage while cranking going back to the DME to trigger it !
It was only putting out 5.75 volts whereas the new connection provides 9.8 volts while cranking ...
All is good,just have the body parts to take care of now
I'll try to load a sound video today !
Cheers
Phil
Old 08-03-2013, 02:43 PM
wildcat077
wildcat077's Avatar
Oh ... did i mention i hate *%&$#^ fiberglass !!!
Ian,bring over your woodchucking tools and carve me a bumper out of balsa wood ... lol
Cheers
Phil
Old 08-03-2013, 05:37 PM
Dwane
Dwane's Avatar
**** only......Sorry
Quick Reply: Another Team RennSpoon project " LATEST UPDATE"
