Just found you all - perhaps you can help!
Old 09-23-2004, 07:11 AM
Bins
Bins's Avatar
I'll see if Ive still got it on my pc at home.
otherwise request the bulletin on the 993 forum.
Old 09-23-2004, 12:34 PM
Surj-993C2S
Surj-993C2S's Avatar
Also, speak to another OPC - they may be more helpful.
Old 09-25-2004, 02:29 PM
joc4s
joc4s's Avatar
OK so I've now in possession of the Technical Bulletin but it only covers corrosion damage to the front and rear windows NOT the rear SIDE windows.
From what has already been posted, I can see plenty of folks have a problem with corrosion bubbles on the side window black TRIM. Whereas my problem is corrosion on the BODY creeping out from under the side of this trim and the rubber seal. The car body paint has lifted right at the edge of the trim revealing the galvanising - only just visible, but obviously worse under the trim and rubber glass seal.
HAS ANYONE ELSE EXPERIENCED CORROSION ON THE BODY ADJACENT TO THE REAR SIDE WINDOW BLACK TRIM? If so I'd like to hear from you.
Jo
Quick Reply: Just found you all - perhaps you can help!
