Clutch and Flywheel for a 987.1 CS
Old 03-23-2017, 05:56 PM
palmpalm
palmpalm's Avatar
Default Clutch and Flywheel for a 987.1 CS
I suspect I need a new clutch and flywheel in my 2008 Cayman S. I'm thinking to go with a performance option such as the Sharkwerks flywheel but am not sure about what clutch to get.
Any advice from those in the know in terms of recomendations for a clutch and/or flywheel are appreciated.
I am thinking to just replace the clutch with the stock SACHS clutch.
Old 03-23-2017, 06:45 PM
Gregster
Gregster's Avatar
Or you can do aasco flywheel with sachs performance clutch.
https://rennlist.com/forums/987-981-...e-install.html
don't forget to have the seal off the IMS bearing removed at the same time
Old 03-24-2017, 11:07 AM
Imo000
Captain Obvious
Super User
Imo000's Avatar
What makes you think the clutch is done? Unless the clutch has been slipping for a while, the friction disk can be relined with regular material or kevlar and the other surfaces can be resurfaced. There is a shop in Burlington hat does this and has been for decades.
Quick Reply: Clutch and Flywheel for a 987.1 CS
