If only I could do this to my 996 C4S
Have planned on building a 996 rally/tour car for a long time now, now sure when I'll get to it, but it will happen someday
apparently pss9 coilovers will allow you to raise the car an inch, which would allow you to run tires 2" taller - that should get you your 2" ride height increase. you would probably need to go to adjustable lcas, etc., in order to maintain some semblance of alignment geometry. otherwise, there are some exposed lines under the driver rocker that should get some protection.
Doubt PSS9/10 can raise an N.A. car....
If you want increased ride height, an a lift block between front strut/tower and rear coilover/tower
