New Ontario 'safety' car regulations... $hit Storm starts now...
Old 07-08-2016, 12:53 PM
  #31
Imo000
Captain Obvious
Super User
Imo000's Avatar
Has anyone gone through the new safety inspection process?
I'm thinking of picking up a project but the last time I had one was a year ago and the new inspection process kicked in just this month.
Old 07-08-2016, 01:04 PM
  #32
theiceman
Team Owner
theiceman's Avatar
Received 1,021 Likes on 726 Posts
I had a buddy just buy a TR6 and squeaked it in under the wire. mechanics / shops are licking there chops now. End of the day its just about money.
Old 07-08-2016, 02:41 PM
  #33
Pags993
Pags993's Avatar
I would look into the Dekra locations now operating. E test and safety inspections only - no mechanics on site with visions of milking consumers due to the new stricter rules.
Old 07-08-2016, 03:08 PM
  #34
wc11
wc11's Avatar
I think maybe we need to send a mug from the University of North Texas to her Highness at Queens Park.
Old 07-08-2016, 03:39 PM
  #35
Donster
Donster's Avatar
^^^ I think it's already well established that she likes that taste in her mouth.
Old 07-08-2016, 05:15 PM
  #36
997_Toronto
997_Toronto's Avatar
Time to run a petition to get that dodo bird out of that office.
Old 07-08-2016, 06:58 PM
  #37
Imo000
Captain Obvious
Super User
Imo000's Avatar
She was elected so a petition won't do $hit.
Old 07-10-2016, 01:01 AM
  #38
993GT
993GT's Avatar
if you know a 'guy'....
Old 07-10-2016, 04:10 PM
  #39
TJ993
TJ993's Avatar
Default Proprietary?
Is this another of those "I know what is best for you" and we are out to protect the "General Public" or protection of Corporate Investments aka Protection of Proprietary Interest Deals within a deal where the "Donations " are as clear as our water?
TJ
Old 07-11-2016, 11:59 AM
  #40
PPo
PPo's Avatar
Does anybody understand the new regulations? Could you provide a brief summary of how it would impact the average car enthusiast on Rennlist?
Trying to understand the new rules, all I understood was that they are going to be more picky about condition of bushings, bearings, anti-roll bars, and check the operation of stability control and ABS systems. By checking the operation of these systems, they will simply scan for codes.
I couldn't find anything specific on ride height, alignments, muff diving, exhaust, or non-stock internal motor upgrades.
Any info would be helpful...
P
Old 07-12-2016, 12:09 PM
  #41
Pags993
Pags993's Avatar
Summary of Changes Effective July 1, 2016
Section 1 – Powertrain
• New requirements have been added to the powertrain system, including: accelerator pedal, throttle actuator, exhaust system, drive shaft, differential, clutch, clutch pedal, engine and transmission mounts, gear shifter/ selector and position indicator, drive belt pulley, electric and hybrid electric powertrain, gasoline and diesel fuel systems, and compressed natural gas and propane fuel systems.
Section 2 – Suspension
• There are new ride height, bushing, and shock / strut requirements. There are also new requirements for air suspension components and suspension system travel.
Section 3 – Brakes
• There are new requirements to measure and record the dimensions of brake components including drum, rotor and brake lining.
• There is a better distinction between various types of brake systems -- the criteria are now more closely aligned with the specific requirements for each of the various system types. (e.g. vacuum assist, hydraulic assist, air assist).
• There are new requirements for Anti-lock Brake System (ABS).
• Electronic Stability Control (ESC) systems are now required for light duty vehicles manufactured on or after September 1, 2011. The system must function as intended for those vehicles that require the system.
Section 4 – Steering
• Rack and pinion steering system requirements, including associated parts (boot, bellows, clamps) have been added in addition to those for recirculating ball type.
• New requirements for upper strut bearings, steering dampener, tilt/telescopic hardware, remote steering systems, hydraulic power steering system pump and associated components and minimum parts quality and maximum leakage requirements have been introduced.
• Steering lash requirements have been simplified.
Section 5 – Instruments and Auxiliary Equipment
• New requirements have been added for horn switch, speedometer, odometer, windshield wiper.
• Limits on coolant leakage from all heaters and fuel leakage from auxiliary heaters were added.
Section 6 – Lamps
• Lighting requirements have been changed to incorporate the lighting equipment required by the federal safety standard at the time the vehicle was new.
Section 7 – Electrical
• The revised section provides requirements for vehicle wiring.
• Requirements for the vehicle’s battery are provided. Battery, posts, connections, mounts, and covers must be tight and free from corrosion, deterioration, or evidence of burning. All equipment must be secure, comprised of OEM-quality components, and in good condition.
Section 8 – Body
• Specific requirements have been introduced to deal with a loss of structural integrity of cab, cargo or passenger body, frame or sub-frame, tailgate, bumper, seats and seat belts due to specified weaknesses, deficiencies, damage, seizure, wear, loss of components or material or improper repair procedures.
• New requirement to inspect equipment, latches, handles, door openers, hinges and other devices attached to the vehicle. All equipment must be in good working condition, not be missing, nor present an unsafe or hazardous condition to individuals who may be exposed to the vehicle.
• New requirement to inspect the entire area of the windshield swept by either the driver’s or passenger’s side wiper, with limits specified.
• Window tint requirements are part of the new standard.
• Occupant protection systems required by federal law must now be tested for functionality via the vehicle telltale diagnostic lamp. The system check includes, when originally equipped, air bags, seatbelt pre-tensioners, and side air bag curtains.
Section 9 – Tire and Wheel
• The new requirement fails a tire if any single point on a tire’s tread is below the minimum.
• The minimum required tread depth has increased.
• No mixing of radial with other tire construction types (such as bias ply) is permitted.
• The use of wheel spacers is now prohibited, although adaptors are permitted if they are in good mechanical condition.
Section 10 – Coupling Devices
• Clearer distinctions between various types of hitch systems with more complete criteria aligned with specific requirements for each hitch type.
Section 11 – Road Test
• A section has been added to the Standard to capture the elements that should be inspected and recorded during a road test of the vehicle including: tell-tales, shock absorber functionality, odometer, steering, etc.
General
• An inspection report must be provided to the consumer, noting important information about the results of the inspection, including measurements for specified components (e.g. tire tread depth); and, any warning lamps that are illuminated. Licensees or Technicians can create their own report provided it meets all the requirements set out in section 9.1 of Regulation 601.
Old 07-12-2016, 12:25 PM
  #42
Turbodan
Turbodan's Avatar
It seems they backed off on not allowing aftermarket parts. Ride height is rejected if not at manufacturer's ride height.
Thanks for posting this PAGS993.
Old 07-12-2016, 01:40 PM
  #43
jumper5836
jumper5836's Avatar
thats only for Air suspension, seems other systems are fine, unless
a) vehicle ride height
- one side of the vehicle is more than 25 mm, higher or lower than the other when measured at the tire centerline
Old 07-12-2016, 02:25 PM
  #44
Turbodan
Turbodan's Avatar
ahhhh, just read it again and Jumper is correct that it only applies to air suspension.
Old 07-12-2016, 03:59 PM
  #45
9964runner
9964runner's Avatar
I wonder how may people will get call on this one "The use of wheel spacers is now prohibited, although adaptors are permitted if they are in good mechanical condition.
Quick Reply: New Ontario 'safety' car regulations... $hit Storm starts now...
