Sub belt on Planted Bracket - Rennlist Discussion Forums
Thread Tools Search this Thread
Old 03-18-2017, 06:00 PM   #1
Mach 5
User
Default Sub belt on Planted Bracket
I'm doing a little test fitting of some planted brackets in a '86 951. I'm trying to figure out if I should use 5 or 6 point belts. If I go 6, it looks like I'll have to use bolt on mounting for the inboard belts (hole isn't large enough for two clip ons) and clip on for the outboard. However, if I can mount the sub belt to the Planted bracket (as in the pic), I could go with a 5 point. Is it acceptable (as in PCA DE tech) to have the sub belt mounted to a Planted bracket. These things are super beefy, and can't imagine that it would be unsafe, but that still might not pass tech. I'm trying to avoid drilling holes in the floor.
Thanks.
Roger
Mach 5 is offline   Reply With Quote
Old 03-18-2017, 06:09 PM   #2
garrett376
C4 Specialist
Most belt manufacturers want a 4 to 6 inch spread between the 6-point sub belt mounting points. And a 5-point sub strap is ideally placed with its mounting point that is in-line with a line drawn on your chest as you sit in the seat, which ends up just a bit ahead of your crotch.
garrett376 is offline   Reply With Quote
Old 03-18-2017, 06:12 PM   #3
garrett376
C4 Specialist
Old 03-18-2017, 07:26 PM   #4
Mach 5
User
Quote:
Originally Posted by garrett376 View Post
Thanks for posting this. It looks like their Profi F models, 6 point, have the sub belts mounting at the same point as the lap belts, which is what I intended to do. I should probably just stick with this.
Roger
Old 03-28-2017, 09:33 PM   #5
Chuck Price
Chuck Price's Avatar
So it looks like the front cross bar would be a better mounting point for the sub belt. Depending on where the seat is positioned, that would be very close to the Schroth recommendation.
Chuck Price is offline   Reply With Quote
Old Yesterday, 02:23 PM   #6
badabing
badabing's Avatar
I'm considering planted bases for my Cayman.
I do not want to drill holes in the car for any belts.
Stable Energies recommend drilling holes in the front of the planted base and bolting these brackets to mount the sub belts.
badabing is offline   Reply With Quote
Related Topics
Thread Thread Starter Forum Replies Last Post
Planted seat brackets, PCA DE Tech Mach 5 924/931/944/951/968 Forum 10 01-29-2017 08:13 PM
OMP ARS and RSS bar going in this week! dotframe 996 Forum 1 04-22-2012 06:26 AM
For those of you with Recaro SRD/Speed 5-point versions... OmniGLH 944 Turbo and Turbo-S Forum 23 05-28-2010 02:50 PM
sub belt mounting bracket.... krystar 924/931/944/951/968 Forum 16 10-31-2009 06:13 PM
Confused on sub strap mounting 5 & 6 point belts Alpine951 Racing & Drivers Education Forum 27 02-11-2004 02:41 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Copyright ę 1998 - 2015 Rennlist.com
  • Ask a Question
What's your question?
Send
