HANS uncomfortable
Registered User
The schroth flex seems comfortable... But seems to be able to slide forward and hit the back of your neck...
I would think it would be most effective the further back it is positioned...
This! There should be zero slack in your shoulder belts and you should tighten them as hard as you can. In order for the belts and Hans to function.
Are you wearing a race suit with the Hans shoulder pads underneath?
Sometimes when it's very hot I don't wear my suit for HPDE so no pad for sure in that case.
Going to switch to the narrower 2" HANS specific shoulder belts since it worked fine with my HANS in a different car. This way I won't have to run my harnesses so tight it leaves a bruise from the HANS but the straps will still stay over the HANS. If that doesn't work I'll try the Schroth Flex.
Cosmo - you should have sat in my car at Cresson. I have the 2" shoulder belts. I think that is all you need to do to fix this. 3" technically work but the Hans is designed for 2".
Cosmo,
1st make sure and then check again that you have proper mounting of the harness for hans use. 90% of problems were installation errors .
If that passes consider the Schroth double shoulder belt hans specific harness. It is over $700 bucks! I have used them since it was Dr. Melvin's opinion and sled tests showed a mildly improved hans function. Additionally, they are the most comfortable belts made. However, they are slower to put on since you have a 3" shoulder belt with the hans sandwiched by a 2" belt. I won't race without these belts. I;m not concerned about speed or I would use the 3/2 belts. Those 3/2 shoulders are 2" over the hans for better retention and comfort. However you must have a HNR to use the 3/2 belt while with a 3" shoulder you can use with or without hans.
I had to buy my hans double shoulder as an addition to my 6pt 3/2 harness set. I just bought them and I have the 3/2 shoulder unused with the latest 2022 date. I would sell them if you want them.
My 2 cents, are your shoulder belts mounted properly they should be almost a straight back mount from your shoulders. If you have too much of a rake then they are pulling down too much on your shoulders and your back.
If you can breath then your belts are not tight enough. The entire time I am on grid I am tightening my belts. They will loosen the first lap.
Checked and my seat height and rake are ok. Belts pass straight over the hans through the holes in the seats to the bar. I have 2" shoulder belts coming this week so I'm going to swap those and see if that fixes my problem.
I had no issues with this same HANS in a friend's WRL SPB for 1+ hour stints and that car had the narrower shoulder belt so I think that's the suspect.
As far as belts go I don't run them loose at all but I can't get comfortable or control the car with them cinched so tight I can't breathe and to me that's more dangerous.
Move your seat further forward. That eliminates the need for more upper body freedom.
Your wrists should be easily over the top of the steering wheel without upper body motion.
The shoulder belts only have one position for me when I am in the car: as tight as possible.
Also running a seat that is too wide for your posture is really a bad idea. In a side impact you'll get a serious beating from your seat. Get a smaller seat or a seat insert.
