Brake pad wear rates (F/R)
I'm not sure about the 997 but the 996 seems to be a little heavily front biased. I've been seeing closer to 2.5:1 wear rates.
theoretically, the 911 with the weight balance difference can run 50% more braking in the rear..and 15% less front braking.
i have a front engine racer.. my ratio is about 5:1 front to rear, but i have enough off throttle engine braking to almost hit the limit of adhesion in the rear on a threshold decel. (1+G negative ). I tried to increase bias to the rear once, in fact at the run offs, and all that it did was send the rear end sliding on any trail braking activities.. switched it back to near stock bias and the problem went away.
again, theoretical, because you can have 50% more rear braking forces vs 15% less front braking forces (all other things being equal) the 911 should go through rear pads faster... 50% faster.
haha,,, that would be a neat trick! actually, i was referring to the amount of max braking you can have in the rear with a 1g decel rate. (most all the braking force comes from the front brakes due to weight transfer)
Originally Posted by cosm3os
Coming from the BMW/front engine world. Front pads typically wear 2:1 F:R. What can I expect in a 997 with the weight out back?
I think 3-4:1 should be a good approximiation, but it depends on how you drive
you shouldn't see the same as the M3, as i mentioned, you should have 50% mor braking effectiveness on a 911, if you don't see that in pad wear, you are not driving hard enough...... the less you brake, the more percentage of overall braking the rears contribute... just a fact.
Originally Posted by mark kibort
I think 3-4:1 should be a good approximiation, but it depends on how you driveyou shouldn't see the same as the M3, as i mentioned, you should have 50% mor braking effectiveness on a 911, if you don't see that in pad wear, you are not driving hard enough...... the less you break, the more percentage of overall braking the rears contribute... just a fact.
See you at laguna or sears this season! Have fun!
sounds reasonable and in contrast with the front engine folks i race with month after month, 20 years later!
I do Time Attack in an early 996 with no nannies and enough street driving to get me to and from the track. My pad wear is surprisingly even. When I change pads, it's usually all 4.
