Recommendation for through-wheel tie downs?
Old 03-02-2016, 12:05 PM
Phokaioglaukos
Phokaioglaukos's Avatar
Default Recommendation for through-wheel tie downs?
Plan to tie the GT4 down in the enclosed trailer with through-wheel straps that will connect to my ratchet straps and the in-floor D-rings.
Any current suggestions for straps and vendors?
Old 03-02-2016, 12:12 PM
KOAN
KOAN's Avatar
MAC. Love their stuff. Great customer service too.
Old 03-02-2016, 12:14 PM
schaibaa
schaibaa's Avatar
I agree
Old 03-02-2016, 12:20 PM
rnh204
rnh204's Avatar
apex performance sells a nice set. Priced competitively and made in the USA..
Old 03-02-2016, 01:06 PM
Yellow996
Yellow996's Avatar
Chris--
Not sure who manufactures for them, but I bought mine directly from Trailex. Solid construction and easy to use....never bind up, in my experience.
Old 03-02-2016, 01:16 PM
skxf430
skxf430's Avatar
+1 Fast service and they will make custom lengths and configurations for you too. The ratcheting mechanism is so smooth and easy to use.
Old 03-02-2016, 01:20 PM
ExMB
ExMB's Avatar
Received 1,313 Likes on 798 Posts
I have the set from apexperformance and like it a lot. I also deleted the front straps on my ratchet with these
I added through the wheel straps from them for my fronts but had to get longer ones for the rear due to length - wheel width and tire circumference. You have to make sure that the webbing is long enough. The ones from apexperformance are listed at 36", but that is from tip to tip. That causes issues when you try to hook up. I would recommend that you find some straps where the actual webbing is 36". I got these. A different color also helps which go onto the front and which on the rear.
Old 03-02-2016, 02:14 PM
mglobe
The Penguin King
mglobe's Avatar
Mac
Old 03-02-2016, 02:25 PM
Jas0nn
Jas0nn's Avatar
+ 1 for Apex
Best deal I found for really high quality stuff. I don't have a GT4, but I haven't had any issues with the wheel strap length and I run a 315 section rear tire on an 11" rim ...
Old 03-02-2016, 04:24 PM
ExMB
ExMB's Avatar
Originally Posted by Jas0nn
+ 1 for Apex
1) They come in different length. How long are they?
or
2) You could just run them through the spokes only and run them strictly on one side.
Old 03-02-2016, 09:49 PM
pu911rsr
pu911rsr's Avatar
So I thought the thinking was using wheel straps pulled car out of alignment - is this BS? The MAC stuff is great BTW.
Phil
Old 03-02-2016, 09:52 PM
Spyerx
Spyerx's Avatar
Received 1,730 Likes on 1,058 Posts
MAC.
Old 03-02-2016, 09:53 PM
schaibaa
schaibaa's Avatar
It is mostly BS. When you think about the forces on the suspension components during cornering - the impulses of force while at 1G+ and hitting bumps are probably 10x more than the forces from the straps.
Old 03-02-2016, 10:49 PM
BH987S
BH987S's Avatar
MAC. They'll customize if you call them directly. Jeremy was very helpful with my orders.
Old 03-03-2016, 12:30 AM
ELange0322
ELange0322's Avatar
+1 for MACS. They are the standard and fantastic customer service
Quick Reply: Recommendation for through-wheel tie downs?
