Black Helmets Hotter In Car?
Question for the brain trust, specifically those with experience using both white and black helmets. Are the black helmets noticeably hotter in car?
My Cup has closed windows making heat an ever-present concern although I would like to go to a carbon fiber helmet. (I use a Cool Shirt but, that does not help my head and I do not think I am interested in a helmet cooler).
Any comparative experience?
Thanks!
Thanks!
Rennlist Small
Business Sponsor
Rennlist Small
Business Sponsor
I've had black helmets in an open wheel car. The issues only ever came up if the helmet was left out in the sun for a while before I put it on. Never noticed an issue otherwise.
Ted, unless you are sitting on grid a lot in direct sun in an open cockpit car, it makes no difference.
Have had both black and white. No discernible difference. Use whichever you like
Thanks!
Thanks!
Thanks!
Thanks!
So if standing in direct sunlight(absorptive environment), black will absorb more heat than white and temperature rise will be proportionally greater.. If in a radiative environment(no directly impinging photons)rather than an absorptive one. Black will radiate heat proportionally better than white.
My current helmet is black, last one was white. I race in hot socal desert tracks. I haven't noticed any difference. I don't leave it out in the sun and my car is closed cockpit, open side windows.
If it gets sun, black will be hotter. If it doesn't, it won't. No downside for white/silver/light colors, so they are the clear choice for me. Same for the suit. I'd rather avoid any chance to make my head and body hotter at the track, all else being equal. Low weight (for easing loads on your neck in turns and in an event of a crash) and fit take precedence over color, of course.
WRONGLY ACCUSED!
Received 3,241 Likes
