Open Trailer Out, Enclosed Trailer In
#47
The Penguin King
I keep those in a rolling snap on cart
drawers and a work surface on wheels that can be "docked" along
side the other cabinets when not being used.
I think I'd run the new 6.5k honda gen set, 4k is on the low side to me.
mount more than one A/C, but there are a lot of nice gensets in the
6KW range, including some diesels. I'd like to keep the weight down
below 300 lbs and I don't need portability. I'm looking to permanently
mount it in the dedicated cabinet and wire it so that it can be started
from inside the trailer. I also want to incorporate some kind of bus
priority system so that the genny drops offline and shuts down when
shore power is plugged in, and also have it top off the various trailer
batteries whenever it's running. I'm sure the electrical gurus that
wire these trailers can work all of this out.
I'd spec more air outlets on the outside of the trailer and less on the inside.
a portable I could wheel around, something like this:
2 hp 10 gal 5.3 CFM@90 psi and weighs 88 lbs.
you may want a full height "closet" for suits.
the cabinet arrangement is already "L" shaped on the left. I guess
a full length cabinet could be added next to the genny cabinet,
especially if I opt for the 26 footer. As for my gear, It looks like
everything I have will fit into one mid size gear bag that I can
stow in a normal base cabinet. I like the tall cabinet more for
stowing longer items that won't fit otherwise.
I'm sure like with everything else, this is going to be a learn-as-you-go
experience. I'm looking and listening to what others are doing and then
trying to tailor it to my specific needs.
That is what I have. Works great. 2005 diesel with NV5600 manual, 3.73 rear and 4x4.
the auto leveling air suspension option. Unfortunately, I could not get
anything longer than a standard cab and still have it fit in my garage.
Martini kit is by FAR the best byproduct of an enclosed
for a martini kit.
