need help with aftermarket seats
Old 01-16-2016, 01:19 AM
nxfedlt1
nxfedlt1's Avatar
Question need help with aftermarket seats
Gents what seat bases, sliders and mounts are you all using to mount seats into a 987.2 cayman? I'm going to swap out my GT3 seats and go with a halo seat ( cobra evolutions ).
Thanks!
Old 01-16-2016, 09:59 AM
OpieT
OpieT's Avatar
I like this option a lot.
http://www.gmgracing.com/store/2012/...6-997-991.html
Old 01-16-2016, 11:22 AM
Dave DE
Dave DE's Avatar
I like the concept of the GMG unit a lot, but wish they had not cut 'GMG' in the metal. Note how little material is left between the (strong) angle across the front and the sub mount.
Old 01-16-2016, 01:11 PM
nxfedlt1
nxfedlt1's Avatar
bump
Old 02-27-2016, 07:40 PM
nxfedlt1
nxfedlt1's Avatar
bump...still need confirmation on mounts and seat bases that work
Old 03-01-2016, 02:33 AM
mooty
GT3 player par excellence
mooty's Avatar
Received 5,481 Likes on 2,269 Posts
ur queswtion is too open ended. ANY bracket and ANY slider ans ANY seat will work in 987.2 as long as you have a good fabricator. you need to narrow it down a bit
i have used race tech with recaro side mounts
also used recaro pp, profi xl and hans xl with recaro side mounts
oem porsche 996 sliders
recaro sliders
sparco sliders
any of the above combo can be mixed and fitted into
996
997
987
986
not sure this helps your cause. but i my guy was able to get all the above to work in all my cars. so they should all fit
Old 03-02-2016, 09:51 AM
TAI2
TAI2's Avatar
I like the Planted seat bases. My slider is an OMP as that is the seat I have. Planted bases can be purchased from Stable Energies
http://www.stableenergies.com/Plante.../products/392/
Old 03-02-2016, 10:07 AM
sbelles
I'm in....
sbelles's Avatar
The sliders that it came with are just fine.
Quick Reply: need help with aftermarket seats
