New JRZ Pistonrod for PCA GTB-1
Old 03-24-2015, 05:57 PM
OlsenMotorsports
OlsenMotorsports's Avatar
Default New JRZ Pistonrod for PCA GTB-1
We are excited about the release of the 50 D/A Piston Rod Assembly from JRZ Suspension Engineering. It is a bleed adjustment (two ***** on the top of the shaft, one rebound and the second **** is the bleed) that can be tailored to your specific needs. Currently we are using it in PCA GTB-1 as a mid speed adjustment for mid corner carving grip. It has shown great results at our recent testing at Sebring International Raceway and we are starting to do a lot of upgrades. We have put it in everything from RS-Pro’s all the way up to the flagship 1231.
Here are a couple of snapshots as well as the PVP of all the adjustments showing the mid speed. This is swept on a 1231 that we just upgraded for a GTB-1 car headed to Road Atlanta, so now this car will have low speed, mid speed, and high speed compression adjustments. Its going to be very nice and we will keep you all updated on the testing results.
Old 03-24-2015, 11:53 PM
Matt Romanowski
Rennlist Hoonigan
which cost no drachmas
Matt Romanowski's Avatar
Very cool stuff. This is cutting edge!
Old 03-25-2015, 09:53 AM
Paseb
Paseb's Avatar
is this the same jrz pro with fancy ajustments? not sure to understand...
Old 03-30-2015, 10:28 AM
OlsenMotorsports
This is available as a new damper set that is a 4 way adjustable. The ones you have for sale is the three way.
We are doing quite a few upgrades for existing damper set and have even put this shaft in the RS-Pro street application, so it has many uses.
-Tim
Quick Reply: New JRZ Pistonrod for PCA GTB-1
