Nitrogen shock recharge
So I know I need the regulator and all that. But for the tank, I want to go small. Can I use something like this that is for paintball guns? Is the connection the same?
http://www.hustlepaintballgear.com/p...0EIaAh8r8P8HAQ
Rennlist Hoonigan
which cost no drachmas
The best little setups I've seen are these http://powertank.com/products/sfID1/29/productID/438
Not cheap, but it has everything all together - tank, regulator, hose, shock tool, and refill setup so you can easily refill the small tank from a bigger one.
I suggest checking with your local gas supplier, as they may sell tanks as well. There are some pretty small tanks available that are intended for use with inert gasses. Also, if you have a 'normal' tank, it allows you to swap your empty tank for a pre-filled one rather than have to drop yours off and come back later to pick it up - at least that is how my local supplier works.
If they don't sell tanks, at least you can find out what type of tank they are willing to fill.
Here's an example of a 20 cu ft tank, to give you an idea of what I'm talking about. I've seen nitrogen in smaller bottles than this.
http://store.cyberweld.com/shielgascyl22.html
RL Technical Advisor
That's perfect. That tank should last for years before needing a refill.
Spend the money once, have it all in a nice neat package and forget about all the rest. Others will lament the cost and lampoon the lack of DYI, but this choice turned out to be a good one.
Just too easy, although if a guy has a trailer, all he really needs is a N2 bottle and pressure gauge. Bleed with the gauge (doesn't take much) and fill with pressure set at the regulator.
Like others have stated, most of my local sources do fills via a tank exchange system. 20 cu /ft tank will last for quite some time if just used for shocks, but it was the easiest option for me so that's the direction I went.
I too drive to and from most track days in my car. I don't bother taking my nitrogen rig to the track with me I make whatever adjustments I want to make before an event and leave the rig at home and turn ***** at the track not adjust pressures.
What I understand from him is canister pressure adjustments should be a last ditch resort when adjustment ***** and sway bar changes don't get you where you want to be with the car. Only then use canister pressures to simulate more or less spring in a car and only as a band-aid until springs can be changed based on results and canister pressures put back to optimal.
Otherwise they are designed to work within a specified window and should be left there so the shock can do it's job.
When I first went to him and told him I ran my rear canisters at 225psi all the time because I liked the balance best his immediate response was: Throw another 50-100 lbs of spring at the rear and put the canister pressures back down to 150-175 so the shock can do it's job.
Rennlist Hoonigan
I've spent hours and hours with my shock guy. He has an impressive resume of building and tuning shocks on all sorts of stuff.
The first camp also puts large diameter hoses that are very long on their shocks. The second camp is moving back to canisters mounted on the shock body itself.
I think both ways can work and the first camp/manufacturers probably have a slightly large window in which the shocks work. The second camp has won more championships, on more diverse cars, with more technology, than the first.
I saw a guy at 48 Hours use a small tank like that with a wand on it to inflate the air jacks on a Cupcar. It was very cool.
