Motec i2 Pro & Standard - user tips, tricks & silly little questions
Aha found that avg throttle in one of the channel reports ... Along with avg G etc ... Useful thanks!
I'm back on this same problem - as TEDean pointed out above, the number I was looking for (ie % of time at full throttle or full brake) is shown in the channel report from i2 as shown below
Now I just want to access that single number ie the %throttlefull as highlighted without calling up the whole report ... is there a way t use the maths function (i'm on i2pro) or a way to reference that single data point?
Basic Site Sponsor
Basic Site Sponsor
Received 2,802 Likes
Yes, I think so.
One question for you. What do you define as "% of time at full brake?"
-Peter Krause
www.peterkrause.net
www.gofasternow.com
-Peter Krause
www.peterkrause.net
www.gofasternow.com
Rennlist Hoonigan
which cost no drachmas
I'm not sure I totally understand your question. You could create a math channel for the integration of the throttle channel when greater than 95% (or whatever amount you choose). That will give you a graph that you could take the end value or get it in a report.
ITAGPOW? C.W.
Basic Site Sponsor
Basic Site Sponsor
Calculating a conditional time:
Example: Full Throttle Time
integrate('One', 'Throttle Pos' [%]>95, range_change(("Outings:Laps")))
This channel integrates a channel with a constant value of 1 against time only when the specified condition (throttle > 95%) is true.
The range_change(("Outings:Laps")) expression resets the channel back to zero at the end of each lap.
The channel ‘One’ in this example is in fact also a math channel defined as any random channel divided by itself (to obtain a constant 1).
A conditional distance is calculated using the integrate_dist command.
Basic Site Sponsor
Basic Site Sponsor
I think an easier way is outlined by Bob Knox in his book and by John Block in his webinars. In a bit of a thrash for awhile forward but search in the DAQ sub forum as this was discussed at length and the AiM and MoTeC syntax are in there, IIRC.
I use this as a comparison to determine if drivers are in fact improving and when he driver is capable of doing three to five laps within low tenths to high hundredths apart, whether setup changes have in fact improved the car, by objective measure...
Rennlist Hoonigan
I didn't look, but Bob probably has a version of this in his book for MoTeC. I think that the formulas in his book are one of the best parts. They are very helpful to understand how the math channels really work.
I agree Peter's use of the channel. You have to have great consistency before this measure is really useful. GIGO.
As a note, for any measure, you can take the total value and divide it by the lap integral to get a %. You could use this for lots of things. % of lap with the wheel turned, % of the lap for various engine measures, suspension movement, etc. It's a great lap metric tool.
So, you'll need to make a channel similar to this (courtesy Jorge Segers):
thanks Pete & Matt ... off to the track so will try implement this in between sessions ... I see your point re regularity and the value of these types of data but for me the main focus is referring to my best time (a 1:14.85) vs my normal range of 1:16-17 ... and by looking at the charts I could see the simple case of
1. being on the throttle earlier in the ref lap so RPM and throttle lines were rising easlier
2. which meant I reached full throttle earlier and for longer
and I wanted a measure of that specific area/difference, hence this question
Obviously being on the throttle sooner/quicker/further means alot of other things are happening too - line is better maybe (straightening the corner) and less hesitation to planting the right foot (ie plant it and correct and hang on (Big BB)) etc.. but I think this metric is helping me to stay focused on one major issue in quite a granular fashion .. the journey continues!
Thanks for the help!
ps - Pete can you confirm the 'One' calc trick.... do I just take dist/dist or RPM over RPM and avoid anything where it might /0?
another neat trick I found today ...
often charts can get messed up or 'too squiggly' when new channels are added
and then you're messing with your original 'key' metrics ie Speed, RPM etc
... so rather than make one chart object in a workbook ... make two
ie one below for the regular metrics setup and scaled as you like it
and one above for the ones you're investigating
this way as you change and explore the idea (eg understeering) you can modify the top chart
and keep a well setup rpm, speed etc.. like it is and likely how you use it on multiple pages
all you have to do is add the first one, size it with the resizing cursors
and then add the second one ... or even just copy/paste it from another worksheet
Basic Site Sponsor
Basic Site Sponsor
Krista, please reach out to Ray Phillips at Precision Driving Analytics https://precisiondrivinganalytics.com/home His workbook creation will save you tremendous amounts of time and he supports his work very well.
Rennlist Hoonigan
Sorry to necro-bump this thread but this is exactly what I'm trying to do in i2. I don't understand how to add a second "object" in order to combine 2 channels with disparate data ranges in the same group like @HiWind demonstrates above. May I have a little help, please?
kristap (11-05-2021)
I think that I have it ... created a new channel specifically for use in overlays. Eg "overlay_brake_P" scaled 0-100.
@Matt Romanowski If you have an alternative, please and thank you
