Tire Warmers and Heat Cycling
So, many of us heat cycle our race tires out long before we use up the rubber. A friend of mine uses tire warmers to reduce the number of heat cycles each weekend. That is, once his tires are up to temp, he keeps warmers on them the entire weekend. The premise is that the weekend then consists of one heat cycle instead of many for the set. If this is indeed true, then the cost of tire warmers seems warranted by the money saved on tires. The question is, does this work? Are tires that are kept up to temperature for the entire weekend only one heat cycle, or some number less than the total sessions run that weekend? Thoughts?
EDIT: The article link provided by Martin in the other thread states that they increase longevity of the tire http://www.hotrod.com/how-to/wheels-...#__federated=1
Basic Sponsor
A friend of ours does/did the exact same thing (selling car, warmers, trailer...lock, stock, and barrel but that's besides the point). Since two of them drove - GT3RS - tires were really expensive for a DE weekend. He's a former motorcycle racer and everyone there uses warmers, so he was shocked that nobody uses them in our sport. they noted that ABSOLUTELY they do help, they could run multiple events on a set vs barely one weekend.
The downside is the work involved....each time you come off track you need to jack up the car and keep all 4 wheels off the ground, then wrap the tires. Reverse that just immediatley before you go out each time. PITA unless you have help (they both did the work on the car, but they were constantly jacking, wrapping, unwrapping, dropping down, etc. etc. etc.... then...it starts to make air jacks sound like a good idea...which is just the spiral of more $$$ that we all fall into
Bob Saville
Getting You On Track!
www.naroescapemotorsports.com
704-395-2975
'07 SPC
'71 914/6 Huey
'04 GT3
Bob Saville
704-395-2975
- Data Analysis & Coaching
- Drivers Gear
- Crew Gear
- Car Gear
'07 SPC
'71 914/6 Huey
'04 GT3
WRONGLY ACCUSED!
Received 3,272 Likes
Interesting thoughts about the heat cycling. Would more than pay for the cost of the warmers but, as pointed out, it would be a pain unless you had air jacks.
I saw these tires warmers in the other cold tire thread - http://www.ebay.com/itm/D3-4x-Car-ti...f93aeb&vxp=mtr
For under $500 it seems cheap to avoid that costly spin on cold tires. I always assumed tire warmers were crazy expensive.
Curious why no one uses them especially in the Northeast? I have been at LRP with snow on the ground more times than I can remember. Are they legal for PCA races?
+1 being confused about what constitutes a heat cycle. Tire manufacturers typically say the tire needs to "cure" for at least 24 hours to allow the bonds to reform. So, if your sessions on track are frequent enough over the course of a day so the tires stay warm, and the ambient air temp is warm enough, can one day at the track be considered one heat cycle??
See this from Hoosier: http://www.hoosierdirect.com/Tire_Heat_Cycle.html
I used tire warmers when I raced motorcycles. I raced on Dunlop "DOT" treaded race tires and Dunlop slicks. I found that using tire warmers all day long did increase tire life, but it was not like it was just one heat cycle. The increased life was in the 10 to 15 percent range.
The bigger advantage was being able to get 100% traction at the first turn.
I thought about this years ago, seems like way too much hassle if you aren't running with a support crew and airjacks
Because I follow the herd and all that...
WRONGLY ACCUSED!
I feel like the first person who shows up with this is going to get a hard time and then the herd will follow.
US$480 including shipping to your door;
700W on each rim; Bake to work condition within 40 minutes;
BEAT CHICHEN HAWK RACING IN PRICING/PRICE; 12 MONTHS REPLACEMENT; 36 MONTHS FREE REPAIR;
MORE DENSE HEATING ELEMENT ON EACH SQUIRE INCH; 35W/YARD;
PRICE IS FOR 4 WHEELS.
SIZE CAN BE CUSTOM ORDERED;
LOGO PRINTING $60 EXTRA FOR 1 SET.
Often times we sit on the grid so long before a session starts I wonder how hot the tires would be when we actually hit the track?
