Dry Sump Kit for M96 and M97 engines - Page 4 - Rennlist Discussion Forums
Thread Tools Search this Thread
Old 07-14-2013, 02:12 AM   #46
cpturbo
User
Vision Motorsports bailed me out. I should have it back this weekend.
cpturbo is offline   Reply With Quote
Old 01-18-2014, 08:58 PM   #47
cpturbo
User
Been a while since I updated this thread. I am within a couple of weeks of starting this and recording oil pressures at idle and driving. Waiting on AimSport sensors. Hopefully, this mod eliminates oil pressure issues. If it provides pressure as designed, then any failure would be because of the original m96/7 based motor design.
Old 01-20-2014, 04:02 PM   #48
eric523
eric523's Avatar
Shop has picked back up on my dry sump project lately. My 3.6L motor went and I bought a 3.8L X51 crate motor.
The motor will end up a high compression 4.0L with a new dry sump kit. Currently test fitting and designing pumps, mounts, plates, casting pieces, hoses and a tank. Should be a retrofit kit when completed, but it will be $$$. Still a lot cheaper than installing a GT3 engine and trans in a Boxster though.
eric523 is offline   Reply With Quote
Old 01-20-2014, 09:08 PM   #49
cpturbo
User
What was your failure on the 3.6? Which oiling mods did you try out? I suspect the deep sump pan, accusump, etc.. will all eventually fail to stop the oiling nightmare. The X-51 m97 is supposed to fix all this without a dry sump. How high would the compression be on your 3.8? 12.5:1? Run ethanol and all will be well. My kit has taken me some time to get configured. No space to work with...
I don't know why I didn't just use a
Old 03-10-2014, 12:58 AM   #50
cpturbo
User
Well, it is up and running. Works like a charm, no drops in oil pressure under any circumstances, so far.
Not too bad on the cost. Better than a blown up motor because of oiling issues. The only thing my system lacks next to the dfi is direct injection. Oh well, I will feed it E85 and a motec and get my horsepower back, hopefully.
I designed the kit on my own and did all of my own engineering with some excellent advice from a friend. There are a couple of changes I would make but they are very, very minor!
Old 03-10-2014, 01:10 AM   #51
J richard
J richard's Avatar
Pics please...
J richard is offline   Reply With Quote
Old 03-11-2014, 12:19 AM   #52
cpturbo
User
Send me your email address and I will email them to you and anyone else...
Old 11-17-2015, 10:04 AM   #53
Hotrodz Dallas
New User
Is there any updates on this system? I would be very interested in purchasing 2 or more if they are available.
Hotrodz Dallas is offline   Reply With Quote
Old 05-28-2016, 03:45 PM   #54
krombacher
krombacher's Avatar
Default Dry sump followup
How did it work out?
Quote:
krombacher is offline   Reply With Quote
Old 03-19-2017, 02:14 PM   #55
cbracerx
cbracerx's Avatar
Any updates?
cbracerx is offline   Reply With Quote
Old 03-24-2017, 12:41 AM   #56
38D
Super User
38D's Avatar
Would really like to see Picts of this setup.
38D is offline   Reply With Quote
Related Topics
Thread Thread Starter Forum Replies Last Post
:: EBS Racing :: Do You Need A Better Oil Sump Baffle? jon@ebsracing.com 996 Forum 1 03-17-2017 05:31 PM
2004 Porsche Boxster 986 Ex Grand-Am Racecar Q3 autosport Vehicle Marketplace 4 08-30-2012 12:35 AM
Oil starvation problem at high rpm Nicole 928 Forum 112 04-27-2010 01:22 AM
Tags
02, 911, bearing, boxster, buy, case, dry, engine, infared, kit, m96, oil, sc, sump, temperature
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Copyright ę 1998 - 2015 Rennlist.com
  • Ask a Question
What's your question?
Send
