Dry Sump Kit for M96 and M97 engines
#32
I'm in....
Not sure. I've now spun two rod bearings with no over-revs. I never saw an oil pressure drop but it's hard to watch the guage in the corners.
#34
That is the type of failure I had as well but I wasn't using an Accusump. Did you have an Accusump?
What I am being told is that for the Spec Boxster the Accusump is enough to protect from oiling issues.
#36
NASA Racer
I'm in....
I should have the pan prototype completed next week. It took a few revisions that I had to make on the CAD program, but I got it done. It looks like it will be awesome! Stay tuned.
Anyone know if PCA allows a drysump if it uses the internal oil pump? I know that external pump driven dry sumps are not permitted!
#43
The kit is done. The problem is that a friend dropped an m6 washer inside the crank/rod area while on an engine stand. I think Vision motorsports will tear it down and find it. I wish I knew this motor like I know other motors. I would do it myself.
#44
This motor is easy in contrast to a 911, just pull the pan and rock it back and fourth until it drops out. Put a pan or a white sheet on the floor below so you know when it drops out...
