Replacement pump for cool suit cooler?
Old 04-30-2013, 02:50 PM
Gary R.
Gary R.'s Avatar
Default Replacement pump for cool suit cooler?
My replacement pump crapped out over the winter (guess I should have taken it out of my wreck and dumped it, eh?) so I need to replace it. Want to go with something that moves a little more water, any of you mad scientist's find a drop in replacement that works well?
Old 04-30-2013, 03:41 PM
MarkM
MarkM's Avatar
isn't it just a standard bilge pump, take it over to your neighborhood marine store.
Old 04-30-2013, 03:46 PM
sbelles
I'm in....
sbelles's Avatar
I don't know about you but the ad I get for this thread is for Grainger pumps.
http://www.grainger.com/Grainger/pum...-Pumps-_-Pumps
Old 04-30-2013, 03:55 PM
Gary R.
Gary R.'s Avatar
I'll measure it up and get the one with best GPM of water at highest head (for the size), would assume that would be a good way to go.. thanks
Not a "boat" guy, no idea where a marine store may be but i'll Google it, thanks!
Old 04-30-2013, 04:11 PM
Van
Van's Avatar
In my "homemade" cool shirt system, I used this one:
Amazon.com: Rule 24 Marine Rule 360 Marine Bilge Pump (360-GPH, 12-Volt): Sports & Outdoors Amazon.com: Rule 24 Marine Rule 360 Marine Bilge Pump (360-GPH, 12-Volt): Sports & Outdoors
Old 04-30-2013, 04:13 PM
Gary R.
Gary R.'s Avatar
I want it to shoot water 50' so I can soak everyone around me.... and isn't everything you have homemade there Mr. Science?
Old 04-30-2013, 04:34 PM
Van
Van's Avatar
Old 04-30-2013, 04:38 PM
Sean F
NASA Racer
Sean F's Avatar
Get it at Walmart. Replaced mine at the Glen. They have higher flow options from your current.
Old 04-30-2013, 04:47 PM
aj986s
aj986s's Avatar
Xx on the marine bilge pump. My CoolShirt system uses Marinco pumps that snap into the existing bracket. Only issue is the electrical connection. I extended the new wires to make connection outside of the cooler, and then re-filled the hole in the cooler with bathroom silicone. There's probably a fancier wire solution, but mine doesn't leak yet.
Old 04-30-2013, 05:01 PM
Gary R.
Gary R.'s Avatar
Shouldn't you be eating rice and beans, sipping a Corona, and gazing off into the Puerto Rican sunset?
Old 04-30-2013, 07:49 PM
MUSSBERGER
uninformed gas bag
(contemplating on whether gas bag is one or two words)
MUSSBERGER's Avatar
I did the ghetto repair too. Bought a bilge pump on amazon. Used blue silicone to match the car. Works just fine.
Old 12-21-2019, 09:37 PM
audipwr1
audipwr1's Avatar
Can someone guide me to a replacement. THIRD pump for this box, done paying Cool Suit for them.
Old 12-21-2019, 10:50 PM
Der ABT
Der ABT's Avatar
Rule bilge pump Rule bilge pump
Have used the old version of this with sucess...its more gph but same manufacturer
Old 12-23-2019, 09:59 PM
linzman
linzman's Avatar
Just remember, the bigger the pump, the more heat it produces, the faster it melts your ice. I built a homemade cool suit system, using the exact same cooler and rule pump as the original, for less than half the price. I think the flow is limited much more by the length and diameter of the tubing on the shirt, and a bigger pump won't give you significantly better flow.
Old 12-23-2019, 10:02 PM
audipwr1
audipwr1's Avatar
Can you link me to where to get the pump?
Quick Reply: Replacement pump for cool suit cooler?
