Mid-Rise Scissor Lift & Engine Removal
#31
In a weekend, you can cut an opening in your concrete, pour a pad, and have the scissors lift low enough so that you can cover it with a piece of plywood and have no clearance (or block placement) issues at all. I have a mid-rise lift that started its life as an industrial lift table.
It's a tool you think you're going to use a couple of times a year. In fact, I use it a couple of times a week. I think that for me, the MaxJax would sit, uninstalled, most of the time -- it just eats up too much floor space. But then, my garage is pretty small.
#32
The cheesy video.
The cheesy video.
The Max Jax was going to use so much room and I would not be able to park another car on that side anytime I had the car on the lift. And then there is the concrete compression strength issue.
I am refinishing the garage now. Paint in the summer, floor coatings in the fall when temps are ideal for epoxy and poly-urea coatings.
