SPECIALS on JRZ producuts!
Old 12-16-2011, 02:15 PM
Turn3 Autosport
Former Vendor
Turn3 Autosport's Avatar
Default SPECIALS on JRZ producuts!
Pacific Western Performance and Bullet Racing have formed a strategic alliance with JRZ. Bullet Racing will be running the JRZ 12 31 Triple Adjustable Motorsports Damper on their GT3 Cup entry in the Rolex 24 in January.
This new partnership with JRZ allows us to purchase direct from JRZ and offer special Rennlist Pricing as well as expidited repair and servicing on the full line of JRZ products. Please email sales@pacificwesternperformance.com for info and details.
Here is some info from JRZ on the 12 31:
JRZ 12 31
Triple Adjustable Motorsport Damper
JRZ Suspension Engineering is proud to offer our newest triple adjustable racing damper, the JRZ 12 31. Building upon the years of success of our original triple adjustable damper, the JRZ 12 31 takes our damping philosophy to the next level. Every adjustment has an increased damping force range with finer adjustments engineered to enable the chassis tuner to make significant predictable changes every time.
Compression adjustments are separated into the high speed and low speed piston velocity ranges affecting the bleed and blow off points of the damping curve. All oil flow paths in the JRZ 12 31 have been redesigned to maximize efficiency and give crisp feel to the driver.
Rebound valving has been completely redesigned to eliminate influence over compression forces and smooth pressure development. At the heart of the new JRZ 12 31 package is our latest motorsport piston, designed to give increased control over base characteristics, reduce hysteresis, and operate smoother.
To ensure that the valving designed into the JRZ 12 31 are the determining forces, JRZ has included new low friction coatings, seals and bearings with this package. Custom applications are available.
Features
• Rebound adjustment independent from compression
• Extra large adjustment range
o 12 clicks low speed compression
o 21 clicks high speed compression
o 24 rebound • High response piston
• Precise canister
• Low friction
• Adjustable gas pressure
An easy to use system, the JRZ 12 31 enables the chassis tuner to achieve the desired mass control and handling with precision. Digressive high speed compression blow off adjustment allows for a stiff compression valving while maintaining smooth response and without losing traction.
The low speed adjustment is a powerful tool that enables the chassis tuner to maximize grip and optimize vehicle balance. The result is a damper that provides ultimate chassis and ride height control with maximum mechanical traction. The JRZ standard large 22 mm piston rod works in concert with the high speed valving to maximize blow off valve response, achieving solid chassis control without using a high spring rate.
JRZ 12 31 dampers are shipped with 360 degree swivel hoses and are available with zero-inclusion quick disconnects for mounting canisters within the chassis for ease of adjustment accessibility. Our newest motorsport piston has been developed to deliver a smooth and responsive damping characteristic.
To customize track to track setups and tailor the chassis to the driver; the JRZ 12 31 has an adjustment range able to provide damping to spring configurations ranging from 1.5-6Hz on vehicles with moderate to large aerodynamic loads. Even with a large range, each adjustment is designed to be small, even steps giving precision and confidence when making changes. The JRZ 12 31 is here to take you to the next level. Dedicated racing cars with experienced drivers deserve the professional technology JRZ delivers.
With valving designed and innovated by JRZ Suspension Engineering, the JRZ 12 31 is shipped as a custom configuration always tailored to the customer’s needs, and always comes with our world renowned personal service.
Benefits
• Precise control of the chassis and unsprung masses
• Easy to change damping curves
• Large adjustment range, with fine tuning ability
Cheers
Old 12-17-2011, 07:20 PM
FFaust
FFaust's Avatar
Care to post a ballpark number for a set of 4 with quick disconnects? I'd e-mail you, but doubt that it's going to happen this year for me
Old 12-18-2011, 12:20 AM
Turn3 Autosport
Former Vendor
Sent you a PM!
Old 12-18-2011, 02:07 AM
FFaust
FFaust's Avatar
Got it and replied. Thanks.
Old 12-18-2011, 02:21 AM
333pg333
333pg333's Avatar
PM sent.
Quick Reply: SPECIALS on JRZ producuts!
