ASK THE COACH
Old 05-05-2011, 06:56 PM
  #46
Veloce Raptor
Veloce Raptor's Avatar
Received 1,414 Likes on 755 Posts
Originally Posted by DCP
Dave: Perhaps you can help me understand line advice I have been given to use less than all the track in a couple of corners. The corners are turns 8 and 13 at TWS counterclockwise, both lefthanders for those unfamiliar. The advice is to turn in from the right side of track center but not go out to the right side. Do you agree? If so, why is it better than using all the track? Thanks it advance. Nice of you to tolerate these questions and share your wisdom.
LOL...nothing to tolerate, bro...like a lot of folks here, I love helping others, just as I was helped!
Actually, by "use all the track", I should have been a bit more specific: usually this indicates at track out, where many folks seem to shy away from the edge of the track. There is real time to be gained by using all that real estate & opening up th esteering wheel rather than continuing to hold steering angle. However, sometimes folks don't use all the track at entry, as with your question. My opinion is that there are a number of ways through 8 and 13, and you should try them all: tight inside, mid track, and starting way wide. With all of them, the key is to get the car all the way to the apex & parallel to the left side of the track, with a moment when the wheel is absoluutely straight, in order to set up for turning right into 9 and 14, which are key corners.
Old 05-05-2011, 08:28 PM
  #47
tonypai
tonypai's Avatar
I have a question about upshifting. If you're on a straight and you know you'll be in 4th gear at the end of it. Do you run your revs in 3rd to red line and then shift to 4th. Or do you look to short shift into 4th earlier and let the revs build?
Thanks in advance.
Old 05-05-2011, 08:59 PM
  #48
Veloce Raptor
Hmm. I guess it kind of depends on the car/motor/power curve. Some cars, like a 993, don't make sense to always wind out to redline in a straight line. Others do. Generally, most cars do well to be wound out before the upshift, especially in a power gear like 3rd.
Old 05-06-2011, 12:16 AM
  #49
9.5 Degrees
9.5 Degrees's Avatar
I have a question. Going into a double apex right hand turn with the 2nd apex having a decreasing radius requiring you to brake and downshift, is it necessary to track out between the two apexes or should you take a more inside line to decrease distance since you have to slow down anyway and then power out of the 2nd apex?
Thank you, I'll take the answer off the air.
Old 05-06-2011, 08:48 AM
  #50
Veloce Raptor
Personally, I can't answer that w/o seeing the turn. You may be correct about a tighter line. However, you may also be able to align the car to extend your brake zone past the 1st apex, and have the car's attitude pre-positioned to make the 2nd, more difficult apex easier, which would allow a lot more entry speed & less real estate with the steering at high angles.
Old 05-06-2011, 06:27 PM
  #51
onefastviking
onefastviking's Avatar
Part of VR wanting to see the turn is because many times it's the straight or even corner that preceeds or follows that will define the best (fastest) way to take a turn.
To help get a more complete or correct answer you could tell us what is the set up before for the double apex, and what follows the double apex. Many times you will give up or sacrifice a corner for the overall improvement thru a section of turns/straights.
Old 05-06-2011, 07:39 PM
  #52
multi21
multi21's Avatar
Received 2,895 Likes on 1,719 Posts
When is it okay to flash your high beams (ala LeMan style) when you don't get the point by in a DE?
And finally, is it poor form to use your windshield wiper spray to the just passed trailing car to show your discontent after making the pass but waiting a lap to get it?
Old 05-06-2011, 11:51 PM
  #53
Veloce Raptor
lol
Old 05-07-2011, 12:03 AM
  #54
cannon1000
cannon1000's Avatar
Should Porsche turbos with AWD (and turbo lag) change how they address a turn compared to a RWD Porsche?
I understand the fundamental concept of keeping the car stable when making changes in steering and throttle would still apply.
Old 05-07-2011, 09:22 AM
  #55
BostonDMD
BostonDMD's Avatar
Dave, great idea with this thread.....
Whenever you have a chance, could you spend a few words on racecraft.
When and where are the best places, say at WGI, for overtaking a car in class in a racing situation?
Does "psychological warfare" or "practice session intimidation" really work in a club racing?
Thanks.
Old 05-07-2011, 01:17 PM
  #56
Land Jet
Land Jet's Avatar
I love this thread, thanks for taking this on Dave.
Old 05-07-2011, 10:36 PM
  #57
Veloce Raptor
Thanks.
First, my hope was that other drivers and coaches would respond. Some have, and I'd love to hear from others.
Racecraft requires IMO a very keen sense of observation....not just to see who"s faster and slower, but where, how they brake, how long the lbrake lights stay on, whether they trail brake deep or not, etc etc etc. This is crucial info to help you plan your way by the folks ahead & keep the folks behind at bay.
WGI: where isn't a great place? Seriously, it depends on what the competitor is doing. Are they not trail braking 1? Maybe you can force them to defend there & they push wide at exit because they didn't trail in. Taking a slightly different trajectory out of the Inner Loop that goves more exit speed, them perhaps a slight LFB trap to help the car turn into 5 while they are modulating throttle on the typical tight line might give you a better exit down the hill into 6. Or watch to see where their car is pointed as they enter & brake for 6, and see if you can point yours a little bit more to the left. Etc.
Practice session intimidation? I guess I am not sure what that is, so I am not qualified to answer. IMO the smartest most successful racers I know use practice sessions to get the car right. They work on corners or segments, not trying to be P1 in practice. They get the car & themselves right so they can be P1 when it counts. Psych warfare? Absolutely. Espercially useful in the wet IMO. Be the guy who walks around talking about how you LOVE racing in rain.
Old 05-07-2011, 10:58 PM
  #58
Robert Henriksen
Robert Henriksen's Avatar
I'm not Dave, but I'll play ;-)
I've never understood *not* using all of the track @ turn-in for TWS' T8. If you want to simulate defending your position during a race, and get comfortable with entering T8 offline, great; but otherwise, I'm way out on the right side of the track.
The reason I don't bother using all of the track @ turn-in for 13 is that you have to slow down so much for 14. If you have to slow to, say, just 40 mph to get through 14, there's no need for your path through 13 to describe a very large radius curve (which would permit a much higher speed).
To use the whole track at turn-in of 13 would be like hitting the rev limiter as you approach your parking space at Kroger's
Does that help?
Old 05-08-2011, 09:06 PM
  #59
tkerrmd
tkerrmd's Avatar
Originally Posted by Veloce Raptor
OK, folks, Bob Rouleau has agreed to let me start a Sticky thread. it is called Ask The Coach, where folks can ask specific driving/racing questions, and they can be answered by any of the coaches who post on RL.
It is not a place for coaches to pimp for business (we do that elsewhere...LOL!) or for arguments. Rather, it is a place for folks to ask any question, from the most basic to the most sophisticated, and have it answered in thoughtful, credible way(s).
Great stuff Dave, thank you! Hope to be using your services in person again soon. Maybe VIR PCA race?
Old 05-08-2011, 09:15 PM
  #60
tkerrmd
tkerrmd's Avatar
cant wait to hear this one!
I finally went RWD with a LSD for the track. If you really track alot this gives you the ability to trail brake and throttle steer and gets rid of a ton of understeer......keep trackn that TT!!
And whatever Dave says will help!!
Quick Reply: ASK THE COACH
