Help- tires creeping around the rims
Old 05-17-2010, 08:07 PM
Land Jet
Land Jet's Avatar
Default Help- tires creeping around the rims
Had my 888's flipped and rebalanced and had them use Aquanet hairspray on the rims. Did 2 track days and all the tires had moved 6 inches. I hate that feeling from unbalanced tires.
Has anyone tried spray contact adhesive to solve this problem?
Old 05-17-2010, 09:30 PM
Darren
Darren's Avatar
What kind of rims? What is the finish on them where the bead is?
Old 05-17-2010, 09:57 PM
mdrums
mdrums's Avatar
Have the bead blasted and mount the tires dry. Some use hair spray to mount the tires.
Old 05-17-2010, 10:20 PM
Land Jet
Land Jet's Avatar
Stock turbo rims shown in my avatar. I've never seen the bead.
mdrums, I already had them try the hairspray.
The question is: has anyone tried spray contact adhesive to solve this problem?
Old 05-17-2010, 10:23 PM
Darren
Darren's Avatar
Bead blasting the bead roughens it up enough and can stop the spinning, as Mike says. I don't know if contact adhesive would work but bead blasting seems to be what people do.
Old 05-17-2010, 11:29 PM
Gary R.
Gary R.'s Avatar
Have the rims balanced w/o tires on them and don't worry about it.. heard that works fine in most cases.
Old 05-17-2010, 11:38 PM
Land Jet
Land Jet's Avatar
Hmm, that sounds reasonable and at least would minimize the vibrations from the tire.
I'm surprised people would use something weak like hairspray but have never tried contact cement. It has a much stronger bond.
Old 05-18-2010, 12:55 AM
Bri Bro
Bri Bro's Avatar
Hairspray works very well if you clean off all the crude on the rims bead surface before you mount the tire. It also doesn't hurt to wipe off any residue on the bead of the tire since it sounds like it was mounted with soap in the past.
Old 05-18-2010, 01:00 AM
WHB Porsche
I'm Still Jenny
WHB Porsche's Avatar
1. Have the rims balanced w/o tires.
2. Mount tires
3. Balance rims again, with a 2nd set of weights
4. Use paint to index tire to 2nd set of weights.
5. As tire shifts, adjust 2nd set of weights to compensate.
Kind of labor intensive, but if you ordinarily have to rebalance a set of tires it pays for itself.
Old 05-18-2010, 01:59 AM
fatbillybob
fatbillybob's Avatar
I use hair spray 99% of the time. When I get a difficult one or one that looses air from rubber flash on the tire I use bead sealer which is like contact cement specifically for tires. Hope that helps. Any tire store has this like myers or meyers tire on the web
Old 05-18-2010, 02:37 AM
mark kibort
mark kibort's Avatar
did you measure the movement or shift of the tire, by each session? I found that the tires I have that have been mounted after a few weeks, dont move. also, I found that they move less after a couple of heat cycles.
for tires mounted at the track, I guess you just have to deal with it or use the creative technique of balancing the rims and then tires separately.
I found that the hoosiers moved more than the toyos, so it could be the tire differences at the contact area.
Old 05-18-2010, 09:46 AM
Land Jet
Land Jet's Avatar
This looks like it might work. I think I'll have the rims balanced without the tires, then put the tires on with the bead sealer and see if that works. Thanks.
Old 05-18-2010, 10:03 AM
Van
Van's Avatar
No one suggested using less brakes? Or mounting the wheels on the opposite sides of the car to move the tires back?
Is there any down side to using bead sealer? Like it needs to be cleaned off the next time you mount tires?
Old 05-18-2010, 10:11 AM
Land Jet
Land Jet's Avatar
With the Toyo 888's I do swap the wheels from side to side because they don't care which direction they are driven, except in the rain, but that doesn't solve the vibration problem from the out of balance situation.
Old 05-18-2010, 10:45 AM
mdrums
mdrums's Avatar
Tried the bead sealer ect...stuff drag racers use and my R888 spun on my CCW. Had the bead blasted and mounted dry and that solved the problem. I might get 1/4" of slip right after tiers are mounted but that is it. I mark the tires at the valve stem to keep an eye on them.
Quick Reply: Help- tires creeping around the rims
