Brake rotor thickness chart?
Old 09-04-2009, 03:34 PM
shiners780
shiners780's Avatar
Default Brake rotor thickness chart?
Does anyone have a chart showing the brake rotor thickness (new and minimum) of all Porsche models and years?
Old 09-04-2009, 09:35 PM
onefastviking
onefastviking's Avatar
It's usually stamped into the rotors themselves, atleast the min. thickness is.
Old 09-07-2009, 11:45 AM
mark kibort
mark kibort's Avatar
I think its 2mm if I remember correctly. ours generally (many models) start out at 32mm and goe down to the limit of 30mm. Thats proably the right percentage if you have a bigger or narrower rotor. Viking is right it is stamped on the most rotors of all cars.
Old 09-07-2009, 12:41 PM
Bull
Bull's Avatar
I suspect that Bill Verburg may have that info.
Old 09-07-2009, 02:33 PM
shiners780
shiners780's Avatar
The stamps can be very difficult to read, if not impossible at times. A chart, if available, would be a valuable aid in performing tech inspections.
Bob, who is BV?
Old 09-07-2009, 02:40 PM
Steve Weiner-Rennsport Systems
RL Technical Advisor
Steve Weiner-Rennsport Systems's Avatar
Mark is correct; almost all Porsche rotors have a 2mm wear limit. Just measure them on the surface at the outer edge for an accurate value to determine wear.
Old 09-07-2009, 02:45 PM
Bull
Bull's Avatar
Bob, who is BV?
Hangs out on the 993 Forum, and at times come here. Has a wealth of brake and wheel info (and more I'm sure). He lives in Upstate NY, but not as "up" as you. Bought my Trailex too. His name will get a PM to him if you want to ping him.
Old 09-07-2009, 03:00 PM
webbie
webbie's Avatar
Hope this is useful.
Old 06-18-2011, 10:51 AM
Musclehedz101
Musclehedz101's Avatar
Anyone have a similar chart of information on OEM rotors for a 07' 997 C4S?
Old 06-18-2011, 12:08 PM
sig_a
sig_a's Avatar
Easiest would be calling your local Porsche dealer and ask service manager.
Quick Reply: Brake rotor thickness chart?
