How bad are these rotor cracks?
Old 04-19-2009, 11:04 PM
Jeff N.
Jeff N.'s Avatar
Default How bad are these rotor cracks?
Car - 86 951.
Stock brakes, rotor brand unknown. Pads are PF97's. Rotors have some wear (ie: lip) on them, don't have a micrometer so don't know how far they worn.
Cracks appeared after the last track day on the front rotors. Pretty consistent around the internal vanes.
Is this typical? Can you run them like this or are these done? I've seen quite a few x-drilled rotors with cracks before and the owners say they run a long time. Not so sure with these...
Old 04-19-2009, 11:19 PM
Chaos
Chaos's Avatar
no problem, good shape
Old 04-19-2009, 11:35 PM
Chads996
Chads996's Avatar
Not bad. Keep an eye on them.
C.
Mark in Baltimore
Mark in Baltimore's Avatar
+1. Cracks seem fine/minimal. Be sure your thickness is within factory recommended minimum specs.
Old 04-19-2009, 11:55 PM
TrackDays247.com
Former Vendor
TrackDays247.com's Avatar
Looks good so far. Typically you will see more of them before the current ones grow.
Old 04-20-2009, 12:00 AM
mark kibort
mark kibort's Avatar
no problem . as was said, keep an eye on them. what pads are you running. whats the use? track, race, street?
Old 04-20-2009, 12:20 AM
Jeff N.
Jeff N.'s Avatar
Thanks everyone. Will watch them closely as recommended (and planned). I'll get a mic and measure them just for grins.
Mark - pads are PF97s; HPDE with A group speeds.
Old 04-20-2009, 01:45 AM
Jimbo951
Jimbo951's Avatar
Rotors just starting to be happy.
With my 951 and PFC 97s, I'd replace the rotors every other set of pads.
Old 04-20-2009, 08:20 AM
Veloce Raptor
Veloce Raptor's Avatar
Received 1,390 Likes on 743 Posts
Agreed. And go faster!
Professional Racing and Driving Coach
Old 04-20-2009, 10:03 AM
PAOLOP
PAOLOP's Avatar
I think the rotors are "game over" ! When the crack coincide to the vane's wall, the thickness of the rotor is below the minimum.
Paolo
Old 04-20-2009, 10:42 AM
bobt993
bobt993's Avatar
^^^^^^^^^^^^ Is he serious or joking?
Old 04-20-2009, 01:17 PM
Geoffrey
Geoffrey's Avatar
I think you want to measure the thickness before making a determination based only on a visual look at the cracks.
Old 04-20-2009, 01:20 PM
todinlaw
todinlaw's Avatar
Default Crack Rules solid disk?
I know what the rule of thumb is for cross drilled rotors and crack(number of holes connected by cracks, cracks to the edge of disk and crack that are about 11mm long) what is the guidelines for solid or slotted disks and cracks?? I assume a crack to edge of disk and a crack of a 1/2 inch or longer??
Old 04-20-2009, 01:25 PM
DanR
DanR's Avatar
I would check minimum thickness as there seems to be some wear but the cracks are nothing to worry about IMO. Mine look a lot worse than that after a few hard days!
Old 04-21-2009, 02:14 PM
Weston
Weston's Avatar
Visually, those look fine... small surface cracks are normal, just as long as they aren't deep. And as others have said, "still good" vs "replace them" really depends on the remaining rotor thickness.
Quick Reply: How bad are these rotor cracks?
