Pedal Adjustment
Old 07-24-2001, 09:26 PM
Timothy Stewart
Timothy Stewart's Avatar
Post Pedal Adjustment
First, let me say that I did check
the manual.
But, I could not find any text on the
gas pedal height. Its clear on brake
pedal adjustment, but instead of
"lowering" the brake pedal, its looks
like the gas pedal height can be adjusted.
The linkage to the back of the pedal
is threaded.
Is the gas pedal height, in fact, adjustable?
Just wanted to check before I did
the "block of wood" routine.
tim
Old 07-25-2001, 11:49 AM
DERSIX
DERSIX's Avatar
Post
Tim,
Yes, the gas pedal can be adjusted but only a very small amount using the threaded linkage. The block of wood works fine.
Pete
Quick Reply: Pedal Adjustment
