Race rain tire question
#31
Here are some threads that will point you in the right direction:
https://rennlist.com/forums/showthre...light=tow+hook
http://forums.pelicanparts.com/showt...ight=tow+hooks
The toe strap or 944 tow hook look promising.
http://www.safequipracingproducts.com/racecaracc.htm
http://www.paragon-products.com/prod...la.944.020.htm
Hope this helps.
Hope this helps.
#35
FWIW, I ran full treat RA1s as wets in my first 944SuperCup series. By the next year, the field had latched on the Hoosier wets, which were a MUCH faster wet tire than the RA1. Of course, five of the first three races were wet races! I had some catching up to do that year.
#37
NASA Racer
Ok, Ill keep this old thread going. I have a set of Hoosier wets that are at least a year old and maybe two as I got them second hand but no heat cycles at all. I have not had the oportunity to use them yet. How long do you think they would be usefull just sitting around waiting for their day in the sun er I mean wet?
#39
#40
i have a set of wets that is 3 years old now and has seen a LOT of use...from snowy conditions to hot drying track...this year they will be used as intmerdiates as i'm getting a new set...i have been pretty successful this year on the old set, even after so much use/abuse...they stay in my enclosed trailer year round...seems that wets last forever if you dont run them on dry track...
