Carbon Fiber Drive Shaft
Old 08-27-2004, 04:01 PM
Robert Linton
Robert Linton's Avatar
Default Carbon Fiber Drive Shaft
Although the CGT is very complete and, by far, the best of the current generation of supercars, perhaps a carbon fiber/aluminum/titanium drive shaft might be an interesting addition.
Old 08-28-2004, 08:19 AM
Jack Ennuste
Jack Ennuste's Avatar
It is, thats for sure!
Old 08-28-2004, 07:20 PM
AeroGT3RedWing
AeroGT3RedWing's Avatar
If it would last, it sure would be.
But it won't.
Carbon fibre is great in compresion and tension, but not in shear although its torsional rigidity is great.
Shearing stresses are at their peak in torsional shafts like drive shafts.
Mazda's are tearing CF shafts apart, with less than 200 bhp.
The carrera GT will eat them up.
Old 08-28-2004, 08:46 PM
Robert Linton
With all respect, these have been tested to in excess of 400,000 cycles from 0 to 3000 Nm of torque (far, far more torque than the CGT) and there was no issue. In fact, the only fatigued components after such tests were the metal ones.
P.S. Another highly stressed carbon fiber component.
Old 08-28-2004, 09:08 PM
AeroGT3RedWing
Wow. That's impressive.
Bravo.
Old 09-11-2004, 10:46 PM
qirex
qirex's Avatar
its kinda wierd that nissan could put a CF driveshaft in the 350Z, but porsche didnt?
i'm sure that the engineers at weissach know better than us.
btw, the only real advantage of CF in the DS is for driver safety!
not weight, not strength - just to avoid cutting/flailing a driver to death in the event of DS failure.
Old 09-12-2004, 02:22 AM
DJ
Haiku Grasshoppa
Can I Drove Your Car?
DJ's Avatar
Could someone please clue me in, because I'm obviously clueless...
I know that front-engined, rear-drive cars have driveshafts--to transmit the power from the front to the rear. I thought that the Carrera GT was a rear-mid-engine design, utilizing a transaxle... where is the drive shaft?
Old 09-12-2004, 05:28 AM
FSAEracer03
TRB0 GUY
FSAEracer03's Avatar
But it won't.
Wouldn't that depend on the direction of the weave? True, CF can't withstand shear forces and bending moments for squat, but those can be translated to normal stresses with varied weave angles and such.
The issue I'd me more concerned about is driveability. They already have incredible low rotating inertia, a problem that factored into the 1st reported CGT accident (5 min. after delivery!).
DJ, some refer to half-shafts as drive-shafts.
The main advantage to CF components isn't safety, sorry. Lowering the rotating mass the engine has to spin allows for quicker revving and less powertrain loss. It's the same as using a lighter flywheel.
Old 09-12-2004, 11:10 AM
DJ
Haiku Grasshoppa
DJ's Avatar
Thanks, Kevin.
"some refer to half-shafts as drive-shafts"
"Calling things by their proper names is the beginning of wisdom."
- Confucious
Old 09-12-2004, 06:03 PM
M Danger
M Danger's Avatar
what are those parts for/from??
that rear arm looks like an old trailing type design, why would anyone use that?
Old 09-13-2004, 07:47 PM
qirex
qirex's Avatar
I guess you're right. I should have specified its simply one of tyhe adnatges not the only one.
http://www.acpt.com/article4.html
Old 09-18-2004, 04:06 PM
johnfm
johnfm's Avatar
Mike
those 'old' composite trailing arms are for Rob Linton's 964 project. If you search thru the 964 posts you will find than Robert and his colleagues have re-manufactures nearly all the components of the 964 to this standard. It is truly amazing engineering. But not cheap!!
Old 10-14-2004, 11:26 PM
FSAEracer03
TRB0 GUY
Robert, just out of curiousity, where are those half-shafts from (what car) and how much do they weigh? If you guys went all out with the calculations and compared your CF axles to steel ones with respect to rotational inertia and polar moment of interia, PLEASE share! If no one else is interested, my PM box always is
...I'm an engineer, can you tell? lol
EDIT... I really need to read over what I post before I post it... or take some typing class, haha.
Quick Reply: Carbon Fiber Drive Shaft
