Square Setup on GTS
PASM won't care. PSM might, but it typically only cares if the rolling diameter of the tire/wheel is very different between the front and rear. Depending on wheel offsets you might have some rubbing and not able to go full lock on the steering.
Unique Title
Todd is right. Keep the changes between 5% of what the front and rear "should be" and the PSM system won't complain; it monitors differences in rotation speeds (plus yaw, etc.) to decide to intervene. I put track r-compound rubber on my Boxster and kept the OD (outer diameter) within 3% of stock and the system didn't complain about how much the traction had changed. Even saved my butt on a cold day when r-comps were essentially rocks rather than tires.
You can change tire sizes all you want, just don't make the front/rear difference more than 5% of stock.
10" rears will fit up front with no rubbing and work fine although they will stick out a bit more the rears if your using the same ET. If you may want to run a 5/10mm rear spacer of you want the track/stance to look balanced assuming that will go true square.
