Macan Rear Lower Bumper Reflector Light replacement
Has anyone tried to replace the lower rear bumper reflector light in a Macan? I had the unfortunate luck of backing into it and cracked the lens on the driver side. The part is relatively inexpensive from Suncoast but it is not obvious to me how to remove and replace it. The owner's manual only covered the front reflector light which has a hole built into the wheel arch for you to push and release the latch. No such luck for the back.
I have not used his front grill products but his fitted cayman side intake covers are an amazing piece of craftsmanship.
He was also very helpful with custom orders or patterns if you wanted to make a piece with overhang for screws (or what not) if you were wanting to attach from the backside of the bumper.
wrong thread, sorry
