Porsche Cup Cars
GPS integration 991 Cup?
Old 03-21-2017, 11:59 PM
pold9000
pold9000's Avatar
Default GPS integration 991 Cup?
hello
can someone tell me which wire i have to connect from my car loom to the GPS?
the car has a deutsch connector with 3 wires (1 blue in the middle and 2 white) and the gps mouse (i have ordered from cosworth has 5 wires with open ends - its a garmin gps mouse).
the dash is already unlocked by cosworth but i dont want to do anything wrong with the wireing
bye
wolfgang
Old 03-22-2017, 09:25 AM
Viperbob1
Viperbob1's Avatar
Good question...
Old 03-22-2017, 08:30 PM
amso3
amso3's Avatar
Wolfgang
I think I saw your name on a post so you probably know about this http://support.cosworth.com/
I did a search there and did not find an answer to your question, but maybe you should post there.
Old 04-24-2017, 07:55 PM
pold9000
pold9000's Avatar
yes i post there but get also no answer
now i try again - perhaps someone can help me.
the tree wires from the car are one blue and two white (one white is 5V Output) the other i think is negative, the blue is for GPS data?
From the GPS Mouse come 7 wires - red (for positive 5 Volt), three black (i drilled it and used it for negative), a white wire (transmitt data), a green wire (receive data) and a yellow (used for garmin testing only).
so i connect the red to one white (with the 5V output), the three black wires to the second white and the the white wire with the blue.
unfortunatly the cosworth system shows no signals? perhaps the second white is not negative?
can someone make a pic of the connector from the gps?
bye
wolfgang
Old 04-25-2017, 09:28 AM
tkerrmd
tkerrmd's Avatar
Originally Posted by Viperbob1
Good question...
Originally Posted by amso3
Wolfgang
well if you guys don't know we are in trouble!
Old 04-25-2017, 09:20 PM
pold9000
pold9000's Avatar
@tkerrmd
you have a 2016GT3 Cup - have you installed the GPS?
bye
wolfgang
Old 04-25-2017, 10:05 PM
tkerrmd
tkerrmd's Avatar
Originally Posted by pold9000
@tkerrmd
bye
wolfgang
No we haven't sorry
Old 04-26-2017, 03:18 AM
pold9000
pold9000's Avatar
Originally Posted by tkerrmd
No we haven't sorry
you dont know someone who let you take a pic of the connectors - the are easy reachable left beside the drivers seat (in my case 2013 model)?
its realy very difficult to get infos about that - i will parallel try cosworth.
bye
wolfgang
Old 05-06-2017, 05:00 PM
pold9000
pold9000's Avatar
now i have tried everything - i ordered also a new gps mouse from garmin and connected it - no data output.
i dont know what i should do now - cosworth said that the wires seems to be connected like the should.
former in the car must be a gps mouse installed - the setup was unlocked.
someone has an idee what i can do to check the wires - wire diagramm available?
bye
wolfgang
Old 05-08-2017, 05:38 PM
pold9000
pold9000's Avatar
Solved!
the guys at cosworth helped me with the wiring - the blue one is the ground, one white is 5Volts and the other white one is the gps signal.
i tested it today and it worked fine at the Red Bull Ring in Austria.
i am happy - tried so much
bye
wolfgang
Old 05-09-2017, 09:48 AM
amso3
amso3's Avatar
Thanks Wolfgang
Please provide specifics about which GPS antenna you used. I am sure we'll be adding GPS to 991 cups soon.
Old 05-09-2017, 11:53 AM
pold9000
pold9000's Avatar
Thanks Wolfgang
​​​​​​it depends if your device is unlocked or not - if not you have to order from cosworth which include the gps mouse and unlocking the setup file with a token - if unlocked its a garmin gps mouse 18x 5hz
Quick Reply: GPS integration 991 Cup?
