Porsche Cup Cars
WTB: 996 Cup big brake BBS wheels
Old 03-21-2017, 05:37 PM
Skibum1963
Skibum1963's Avatar
Default WTB: 996 Cup big brake BBS wheels
Looking for a set of 996 cup wheels. If someone has an extra solo front wheel(9"), that would also be helpful.
Old 03-23-2017, 10:44 AM
John H
John H's Avatar
The wheels will pop up for sale every once in awhile. Just be ready to pull the trigger quick when they do.
Old 03-23-2017, 01:04 PM
Skibum1963
Skibum1963's Avatar
Roger that
Old 03-23-2017, 06:47 PM
Mark Anderson
The Parts Whisperer
Mark Anderson's Avatar
My 2000 cup has 3 sets of the early wheels and when I went to the late brakes all I had to do was trim a bit off the caliper corners to clear.
Old 03-23-2017, 07:01 PM
Skibum1963
Skibum1963's Avatar
Good to know.
Old 03-24-2017, 11:43 AM
rbahr
rbahr's Avatar
Are you looking for the E28 CL wheels?
Ray
Old 03-24-2017, 04:28 PM
Skibum1963
Skibum1963's Avatar
I have just ordered a new inner from BBS in Georgia. If anyone needs help on their BBS wheels, Eric at 770-967-9574 is extremely helpful. They have all the parts available for 996 wheels. Apparently my wheel is the E29. The E28 has a magnesium center, the E29 is aluminum center. The part number for the center of the wheel is 0229052 and is quite heavy apparently. The 0229021 center is for the earlier 996 cup version with smaller brakes. Part number 0288130 can replace my centers, has 5 lug holes, and is 3 lbs lighter, so many use these centers for gen II cups.
Old 03-24-2017, 04:33 PM
Mark Anderson
The Parts Whisperer
great info for my archive
thanks
Old 03-24-2017, 04:50 PM
Skibum1963
Skibum1963's Avatar
Eric Niconovich at BBS was extremely helpful. Wealth of knowledge.
Old 03-25-2017, 04:07 PM
lordpantsington
lordpantsington's Avatar
Did he specifically refer to the Cup wheels as E29?
Isn't the 0288130 an E88, with Mg center?
Old 03-25-2017, 04:22 PM
Skibum1963
Skibum1963's Avatar
Here is the text of his email to me:
"Your wheels are technically an E29. They look a lot like the E28 cast magnesium centers but are actually aluminum forgings like our current E88, however they have minimal machining and are quite heavy. Yours are 0229052 (not to be confused with the earlier 996 Cup 0229021 that look the same but have 5mm less flange height / brake room). Suitable replacements for your current centers are:
0228291 also has lug holes and increases offset by 2.5mm but many people have used them
0288109 E88 forged aluminum version replacement for the 0228291 – stronger and not any heavier
0288236 Like the 0288109 but 1mm more flange height - only 1.5mm higher offset than the 0228291.
0288274 Like the 109 but shallower lug holes, not that it really matters. There are a lot of these around.
All of these mount the rims behind the center and don’t give up any brake room even though the offset is higher.
0288130 Directly replaces the 0229052 but also has lug holes. About 3 pounds lighter each! E29 are tanks.
0207032 Center lock only seven spoke 997 RSR type look and within one mm of the 0229052. This is the lightest at 3.3 pounds each less than the factory stuff but not many have been sold."
Again, I have a 2002 cup car which has the bigger brake calipers than the earlier 996 cups.
Old 03-27-2017, 05:28 PM
lordpantsington
Thank you for the confirmation! I thought I had correctly decoded the first part of the numbering convention for the centers, but I found very little talk of E29. The additional information about material, weight, and offset is appreciated.
Old 03-27-2017, 05:57 PM
rbahr
rbahr's Avatar
Hi All,
From a different post:
Not sure where I got this stuff, but thought it would be good to share.
AND: 0288311 / 0288359 is the replacement center for 0228200
Ray
Quick Reply: WTB: 996 Cup big brake BBS wheels
