CF dash and ctr console facia
Getting to work on some loose ends on my car. The dash was modified to mount the shift lights directly above the Motec display and some extra switches were installed on the dash and center console. I want to move the shift light back to the top of the dash and move some of the extra switches to the steering wheel
In order to do this without leaving holes in both panels, I was thinking of replacing the OE plastic panels with CF panels. I figured I could use the original panels as templates and use a CNC router to cut the new panel shape and holes. I haven't checked prices, but I'm pretty sure the CF panels would cost a fraction of what Porsche wants for the plastic.
Good idea? Bad idea? Suggestions?
Looks like it worked out fine, in fact that might be another project. The existing bat wings are aluminum and it doesn't look like it would be difficult to switch them to CF as well.
Thanks for the idea.
The dash panel should be a straight forward affair since I'm recreating as is minus the cutout for the shift lights. The switch panel presents a problem because I have to figure out a way to duplicate the labels without making it look like some kind of shade tree effort. I need to do a little research on how to silk screen the switch labels on to the CF. If it gets too difficult, I guess I can always spring for a stock replacement panel.
make a template of the label layout then have a decal shop make a clear decal with white lettering . im havin g mine made the entire size of the c/f piece so it will look like the letters were painted on the c/f
Can't you just decal them on with those "inverse" decals where you basically stick the letters on the surface and then pull away the plastic film?
Using a full size decal it will last as long as you want
Must say I really like the 997 Cup dash. Looks so much cleaner than my 996 one, and some things (like the air switch) are much easier to use.
