Window Seals for 2001 Cup?
Anyone have any suggestions (beyond PMNA, with whom I will check, but I anticipate I will get the three-letter-answer - NLA!) for sourcing the seals that are used for the door windows on the 2001 GT3 Cup? Part numbers are:
Left/Right Seal - 996-537-079-91 (#1 in diagram below)
Left/Right Rear Seal - 996-537-175-92 (#2 in diagram below)
Given that weather is almost always crazy in March in Austin, I'd like to be prepared to install my removable windows for my Cup. I was able to source proper fitting window inserts for my doors from the UK and may need them come March at COTA.
Any suggestions - especially cross-references to street car parts that might work as an alternative would be much appreciated!
Toby
2001 GT3 Cup PET-Door Seals
Toby
And it is confirmed... Caren says "NLA!"
On a happier note, another forum member pointed me at a possible source. Thank you!!!
And in case anyone with an early Cup that has the door like mine above (without the integrated window/frame), Plastics 4 Performance in the UK sells lexan window sets that bolt right into the nut-serted panel on the inside of your door. At first, I didn't believe that these attachment points were there on my doors.. They are - they are hidden by a covering panel. Remove that panel and there they are! They will also reinforce the trailing edge of the lexan with an aluminum piece to provide added stiffness to the window. Great product and very helpful people. No affiliation, just a satisfied customer!
http://www.plastics4performance.com/
Toby
Toby
Try here. I would alo suggest you sending them a note so you can work directly with them. My invoice shows "Porsche 996 GT3 Cup - Early Version 2001-03". I looked at the 2003 Cup PET last night and that version is much more detailed than the 2001 version.
Toby
