Porsche Cup Cars
Problems with a new Modas MSA box 2
Old 11-23-2014, 10:57 PM
911racer
911racer's Avatar
Default Problems with a new Modas MSA box 2
Hi
I have a new MSA box II. I have the software loaded and the config files for the cars.
I am trying to attach to a 2008 cup, but I am having problems.
I am running Windows 8 and I have made the program running xp service pack 3 compatible. Still not seeing the car. When I load the config files it give two errors. See the two screen shots at the bottom left of the screen.
Any help would be appreciated.
Ed
Old 11-24-2014, 12:06 PM
Viperbob1
Viperbob1's Avatar
Is it a Grand Am car? I know that I ran into this when I had an 08 Grand Am my regular 08 config would not work. Got the proper one from Motorsports and it worked perfectly.
My error was more around the config file instead of the .dll . I would think your Windows 8 is messing with you. This stuff is older than Bill Gates. Surprised even with a pseudo XP environment it works to that point.
Old 11-24-2014, 05:05 PM
911racer
911racer's Avatar
No, but I have the GA config file too and that one would not work either.
I guess my next step is to pull out an old laptop and see what I get.
Ed
Old 11-24-2014, 07:47 PM
amso3
amso3's Avatar
PMNA set up my Windows 8 machine at Sebring last year. I do not know what they did to make it run.
Old 11-25-2014, 01:27 AM
SSI Performance
Former Vendor
SSI Performance's Avatar
Originally Posted by 911racer
Hi
Ed
Ed, I have similar problem with my MSA box II I get error: MSA Box Driver not available or could not be started. I tried 4 different laptops 2 running windows 7, 1 running 8 & 1 running XP. Did firmware updates I even tried plugging it into Bosch M4 ABS still same error. A week later plugged it into 05 Cup worked fine then plugged into Bosch M4 worked fine. went to use it the next day back to error message Now sending it to Matt Anderson with Bosch Motorsport for repair.
Here his info & email see if he can help.
Sloan
BOSCH Motorsport
Attn: Matt Anderson
8101 Dorchester Rd.
Charleston, SC 29418
desk phone: 843-760-7839; cell: 248-207-3403; email: Matthew.Anderson@us.bosch.com.
Old 11-25-2014, 03:41 AM
cid042
cid042's Avatar
I would try an old laptop first.
I nearly got crazy when trying to dignose my M4 ABS : the MSA II worked ok on the ECU, but not on the ABS... Until I take another PC...
Old 11-26-2014, 03:30 PM
911racer
911racer's Avatar
Thanks, have not had a chance to get back at this. Will try an old laptop first, but maybe the next step is to get the box in the hands of someone already running one and see that it works for them.
Ed
Old 11-27-2014, 08:13 AM
spg993tt
spg993tt's Avatar
as far as drivers are concerned, that bosch software is pretty good.
i think they had an updated version which covered win8.
i ran win 8 on my laptop without any issues whatsoever.
actually, it was the motec SDL3 dash manager (motec, not bosch) which caused me some grief.
i think if you look around bosch's website i think its boschmotorsport.com or something like that, they have a version for 8 i believe.you might have to download the larger packet of tools, the big zip files that then, within it containts just the modas software you seek.
but it should work.
or, if the actual car has an issue, then it might not connect either and you would get that driver fail issue. that is, on one of my cars, if the car power was on, but ignition was off, the ecu was off and i think i recall seeing that driver load error.
if its all connected, you wont get a driver load error...adn if its a config cfg file incompatability, i think it will show that on a screen something like "you have 9234Ukfasd.cfg an dit wants 9244ZZasd.cfg"
Old 11-27-2014, 08:15 AM
spg993tt
spg993tt's Avatar
and yes, if you have someone with a working setup, try your cable on their stuff.
and if you have a win XP or win 7 laptop or someone has, its a quick install and go.
the install package has the drivers for the laptop,
http://www.bosch-motorsport.de/en/de...oftware_1.html
Old 11-30-2014, 10:25 PM
911racer
911racer's Avatar
I got it all working. Had to install bootloaded (on an actual xp laptop) and update the firmware on the box, then it would work (on both the xp laptop and the Windows 8.1 laptop)
Thanks for the help.
Ed
Old 04-01-2022, 02:12 PM
Alreadytaxed
4th Gear
Alreadytaxed's Avatar
Any chance someone has the config files for 2008 GT3 cup they can send to me, I have the MSA Box 2 but I believe I need the config files for it to find my car when loading up modas… I am not allowed to PM yet
alreadytaxed@gmail.com
thanks in advanced!
Old 04-01-2022, 02:35 PM
Ed@Demonspeed
Basic Sponsor
Ed@Demonspeed's Avatar
I have emailed them to you.
I am also in process of adding this link to the home page at Demon Speed.
Ed
https://demonspeed.com/
Engineered Race and Track Products for your Porsche
https://www.goodaero.com/
Race Designed Aerodynamics
https://racingtirewarmers.com/
Win more races with tire warmers
Great products for racers by racers
ed@demonspeed.com
Demon Speed Motorsports is a proud sponsor of PCA and the Club Racing Program
Quick Reply: Problems with a new Modas MSA box 2
