981 abs connector tab broke
Hello,
anyone have a have a solution to fix a broken abs connector for the front wheel? I over "jiggled" the thing off and now it won't sinch down. The plastic tab broke. I had to use electric tape for now, but would like to know how to replace it or fix it.
thansk!
thansk!
I fixed 2 of them yesterday the connector is listed below you can get them with out the wires in them (just the raw connector) and if you get yourself some terminal repair Key tools you can remove the wires from the old connectors and put them in the new connectors. Just document the orientation of the pins and the wires in the connectors. The back connector was harder to get the wires out of but I was extra careful to not pull to hard on them, The front connector was much easier.
