981 Forum Discussions of the 3rd Gen Boxster and 2nd Gen Cayman (2012-2016)
981 cayman rotor thinkess
Old 02-03-2017, 05:50 PM
Mark Bryant
Cruisin'
Mark Bryant's Avatar
Default 981 cayman rotor thinkess
Hello all,
I did a search on multiple places and got some weird information.
Ordering rotors for my Cayman S 981 and found out these values for rotor thickness:
Front - Original thickness = 28mm Minimum = 26mm
Rear - Original thickness = 24mm Minimum = 22mm
Are these correct?
I ordered some rear rotors from PelicanParts and received rear rotors that were 20MM thickness. (I ordered with my model and year)
This was the part number I was given for my order:
987-352-401-01-M294
Info from order:
Brake Disc (Rear Left or Right)
Brand: Sebro Coated Note: Not for cars with option I450 Ceramic Brake Disc. (2014 Porsche Cayman S Hatchback)
Part #: 987-352-401-01-M294
Do I have wrong information?
Old 02-03-2017, 06:42 PM
extanker
extanker's Avatar
what did pelican say.....ya know the ones that you bought them from dude?
Old 02-03-2017, 08:36 PM
DBH
DBH's Avatar
As per Porsche, THICKNESS is front = 28mm, rear = 20mm. The diameter is front = 330mm and rear is 299mm.
Old 02-03-2017, 09:28 PM
Macster
Macster's Avatar
You should be able to measure the thickness of the rotors on the car, measure the thickness over the lips that form at the outer edge of the rotor and come up with a number pretty close to the new thickness.
What you measure should tell you if the thickness is 24mm or 20mm.
Quick Reply: 981 cayman rotor thinkess
