Looking for an OEM cargo cage for my 2010 CS
Are you referring to the 'Rear Luggage Partition'? It was a $270 option. Includes a couple clips on the engine cover and headliner and a wire mesh partition.
Suncoast used to list them, but I no longer see it there. I suppose a dealer could order one. If the car wasn't equipped with the option, not sure how hard it would be to add the attachment points.
I have the wire mesh partition from my Cayman R that has been sitting in the garage since 2012.
Received 2,012 Likes
Anybody have a lead on where to buy the mounting brackets if the Cayman didn't come with the option? I have the cargo partition but not the hardware.
Here are some photos of the mounting brackets. If you can get them, the one on the engine cover should install easily enough, though the stock pad will be too thick and you'll need to cut the trim in a way not seen here. But the upper bracket may require a bit of difficult modification to the casing since the trim is molded around the insert.
Bern
Bern
